I am having a problem getting my xbox to connect to Xbox Live using AT&T uverse. If I plug the ethernet cord directly from the 2wire gateway into the xbox, it connects no problem. But when I plug the 2 wire into a d-link router and then into the Xbox it can connect to the network, but not the internet. My computer works fine when plugged into the d-link. When I goto to test the connection through the xbox it tells me my DNS settings may be off. I follow the steps it gives me to enter it manually but that does not work. Also, when I run ipconfig /all it shows the DNS as the ip for the 2wire, shouldnt it show the IP for the d-link? I am also not able to login to the d-link settings from my computer using the ip address. Any suggestions on how I can access my d-link settings(need to encrypt it) and get it to recognize that the xbox is connected?
ETA - The AT&T router is plugged into a LAN port on the D-Link and not the WAN. Not sure if that makes a difference.
Thanks,
Mark.
Thanks,
Mark.
