SOLVED Athlon II X2 270 How much can i take it too!
Banjozvin
How so i started playing the game called "Black ops 2" wich is pretty cool and my FPS is around 50-100 when alot is happening. But the CPU usage is at 100% all the time and that makes the game do some lag spikes some times. So today i said "Let's overclock this CPU" so i started slowly, and here's is where i am now!
My motherboard is called "ASRock 990FX Extreme3. i don't know if "Ram" has anything to do with this BUT i got 4gb DDR3 HyperX ram NB Freq = 2200
How long can i go with this and what do i need to do to go even longer!
Hope i gave enough info!
Well, you certainly could go higher with a better cooling: I see you hit 61°C max which is already well over the advised 55°C max.
Good news are that your vCore tops [email protected], so you gave still something like 0.08/0.09v and that your CPUS is a C3 stepping one.
So, better cooler, 1.45/1.46v max, 55°C max, and you might be able to reach 4GHz...
But isn't the 61°C the highest it has ever reached?
Because it's said 61 even before i overclocked so it might be long time, there was a period where one of my cabinet sides weren't on it could be from there.
4.1 with stock voltage is:
:bs:
Lol! no way!!!! Unless he runs LN2 (and even, I doubt he could hit such high freq@stock vcore).
To answer your question, nope, it's the max temp since you've started HWmonitor.
What you need to download is prime95.
It's a stress test that will take your CPU to its max load and temp.
Have a (long and deep) look at this guide:
http://www.overclockers.com/forums/showthread.php?t=596023
It's for PhenomII's, but Athlon's OC the same way.
Thanks! I hope my english didn't make it too hard for you to understand me :p
Still working on it ;) But thanks again :p
Cheers!
