ATI (fglrx) only as root, not as user.
kel_p
Amsterdam
I posted this at the Archforums also but thought it can't hurt to try my luck here also :)
I just reinstalled Arch, but I have a problem getting fglrx setup.
I had it working just yesterday with my current xorg.conf but today I have a strange issue..
When I "startx gnome-session" AS ROOT fglrxinfo gives me all the ATI-messages I want to see, AS USER I get Mesa-stuff.
User is in all the groups as with my previous (working) Arch-install, including video.
Everything seems to be fine but ONLY when starting X as root, I'm lost!
lsmod | grep fglrx gives...
Code:
fglrx                 687156  17
agpgart                27224  2 intel_agp,fglrx
xorg.conf.. (I know this one worked yesterday, I use the same one on other installs)
Code:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
	Identifier     "Default Layout"
	Screen      0  "aticonfig-Screen[0]" 0 0
	InputDevice    "Generic Keyboard"
	InputDevice    "Configured Mouse"
EndSection
Section "Files"
	# path to defoma fonts
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/X11R6/lib/X11/fonts/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
	FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load  "dbe"
	Load  "i2c"
	Load  "bitmap"
	Load  "ddc"
	Load  "dri"
	Load  "extmod"
	Load  "freetype"
	Load  "glx"
	Load  "int10"
	Load  "vbe"
EndSection
Section "ServerFlags"
	Option	    "AIGLX" "off"
EndSection
Section "InputDevice"
	Identifier  "Generic Keyboard"
	Driver      "kbd"
	Option	    "CoreKeyboard"
	Option	    "XkbRules" "xorg"
	Option	    "XkbModel" "pc104"
	Option	    "XkbLayout" "us_intl"
EndSection
	Identifier  "Configured Mouse"
	Driver      "mouse"
	Option	    "CorePointer"
	Option	    "Device" "/dev/input/mice"
	Option	    "Protocol" "ImPS/2"
	Option	    "Emulate3Buttons" "true"
EndSection
Section "Monitor"
	Identifier   "aticonfig-Monitor[0]"
	DisplaySize  432	324
	HorizSync    30.0 - 81.0
	VertRefresh  56.0 - 75.0
	Option	    "VendorName" "ATI Proprietary Driver"
	Option	    "ModelName" "Generic Autodetecting Monitor"
	Option	    "DPMS" "true"
EndSection
Section "Device"
	Identifier  "aticonfig-Device[0]"
	Driver      "fglrx"
	Option	    "UseInternalAGPGART" "no"
	Option	    "VideoOverlay" "on"
	Option	    "OpenGLOverlay" "off"
#	BusID       "PCI:1:0:0"
	Option	    "Centermode" "off"
	Option	    "PseudoColorVisuals" "off"
EndSection
Section "Screen"
	Identifier "aticonfig-Screen[0]"
	Device     "aticonfig-Device[0]"
	Monitor    "aticonfig-Monitor[0]"
	DefaultDepth     24
	SubSection "Display"
		Viewport   0 0
		Depth     24
		Modes    "1680x1050"
	EndSubSection
EndSection
Section "DRI"
	Mode         0666
EndSection
Section "Extensions"
	Option	    "Composite" "Disable"
EndSection
/var/log/Xorg.0.log gives warnings but none seem to be related to this issue..
Code:
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: UNKNOWN
Current Operating System: Linux asla 2.6.22-ARCH #1 SMP PREEMPT Mon Jul 23 21:13:22 CEST 2007 i686
Build Date: 08 April 2007
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug  3 07:24:54 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "aticonfig-Screen[0]" (0)
(**) |   |-->Monitor "aticonfig-Monitor[0]"
(**) |   |-->Device "aticonfig-Device[0]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/share/fonts/X11/misc" does not exist.
	Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(WW) FontPath is completely invalid.  Using compiled-in default.
(==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/100dpi:unscaled,
	/usr/share/fonts/75dpi:unscaled,
	/usr/share/fonts/TTF,
	/usr/share/fonts/Type1
(==) RgbPath set to "/usr/share/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Option "AIGLX" "off"
(**) Extension "Composite" is disabled
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) Loader magic: 0x81c44a0
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 1.1
	X.Org XInput driver : 0.7
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
	compiled for 7.2.0, module version = 1.0.0
	ABI class: X.Org Video Driver, version 1.1
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2570 card 1462,7280 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 1462,7280 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 1462,7280 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24d7 card 1462,7280 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,24de card 1462,7280 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 1462,7280 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24db card 1462,7280 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,24d1 card 1462,0080 rev 02 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 1462,7280 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24d5 card 1462,0080 rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,71c6 card 174b,0850 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,71e6 card 174b,0851 rev 00 class 03,80,00 hdr 00
(II) PCI: 02:06:0: chip 10ec,8169 card 1462,728c rev 10 class 02,00,00 hdr 00
(II) PCI: 02:0a:0: chip 1106,3044 card 1462,728d rev 80 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) Bus 0 non-prefetchable memory range:
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[b]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000d (VGA_EN is set)
(II) Bus 1 I/O range:
	[0] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[b]
	[1] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[b]
	[2] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[b]
	[3] -1	0	0x0000ac00 - 0x0000acff (0x100) IX[b]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xffc00000 - 0xffcfffff (0x100000) MX[b]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xbfe00000 - 0xdfefffff (0x20100000) MX[b]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
	[0] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[b]
	[1] -1	0	0x0000b400 - 0x0000b4ff (0x100) IX[b]
	[2] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[b]
	[3] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[b]
(II) Bus 2 non-prefetchable memory range:
	[0] -1	0	0xffd00000 - 0xffdfffff (0x100000) MX[b]
(II) Bus 2 prefetchable memory range:
	[0] -1	0	0x88000000 - 0x880fffff (0x100000) MX[b]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc RV530LE [Radeon X1600] rev 0, Mem @ 0xc0000000/28, 0xffcf0000/16, I/O @ 0xa800/8, BIOS @ 0xffcc0000/17
(--) PCI: (1:0:1) ATI Technologies Inc unknown chipset (0x71e6) rev 0, Mem @ 0xffce0000/16
(II) Addressable bus resource ranges are
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) OS-reported resource ranges:
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[b]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[b]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[b]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[b]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xefffffff to 0xdfffffff
(II) Active PCI resource ranges:
	[0] -1	0	0xffdff000 - 0xffdff7ff (0x800) MX[b]
	[1] -1	0	0xffdfff00 - 0xffdfffff (0x100) MX[b]
	[2] -1	0	0xffeff900 - 0xffeff9ff (0x100) MX[b]
	[3] -1	0	0xffeffa00 - 0xffeffbff (0x200) MX[b]
	[4] -1	0	0x88100000 - 0x881003ff (0x400) MX[b]
	[5] -1	0	0xffeffc00 - 0xffefffff (0x400) MX[b]
	[6] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
	[7] -1	0	0xffce0000 - 0xffceffff (0x10000) MX[b](B)
	[8] -1	0	0xffcc0000 - 0xffcdffff (0x20000) MX[b](B)
	[9] -1	0	0xffcf0000 - 0xffcfffff (0x10000) MX[b](B)
	[10] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](B)
	[11] -1	0	0x0000b800 - 0x0000b87f (0x80) IX[b]
	[12] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[b]
	[13] -1	0	0x0000c400 - 0x0000c43f (0x40) IX[b]
	[14] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
	[15] -1	0	0x00000c00 - 0x00000c1f (0x20) IX[b]
	[16] -1	0	0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[17] -1	0	0x0000e000 - 0x0000e003 (0x4) IX[b]
	[18] -1	0	0x0000e400 - 0x0000e407 (0x8) IX[b]
	[19] -1	0	0x0000e800 - 0x0000e803 (0x4) IX[b]
	[20] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
	[21] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
	[22] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[23] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[24] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[25] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[26] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
	[27] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[b]
	[28] -1	0	0x0000d000 - 0x0000d01f (0x20) IX[b]
	[29] -1	0	0x0000cc00 - 0x0000cc1f (0x20) IX[b]
	[30] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[b](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xffdff000 - 0xffdff7ff (0x800) MX[b]
	[5] -1	0	0xffdfff00 - 0xffdfffff (0x100) MX[b]
	[6] -1	0	0xffeff900 - 0xffeff9ff (0x100) MX[b]
	[7] -1	0	0xffeffa00 - 0xffeffbff (0x200) MX[b]
	[8] -1	0	0x88100000 - 0x881003ff (0x400) MX[b]
	[9] -1	0	0xffeffc00 - 0xffefffff (0x400) MX[b]
	[10] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
	[11] -1	0	0xffce0000 - 0xffceffff (0x10000) MX[b](B)
	[12] -1	0	0xffcc0000 - 0xffcdffff (0x20000) MX[b](B)
	[13] -1	0	0xffcf0000 - 0xffcfffff (0x10000) MX[b](B)
	[14] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](B)
	[15] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
	[16] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
	[17] -1	0	0x0000b800 - 0x0000b87f (0x80) IX[b]
	[18] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[b]
	[19] -1	0	0x0000c400 - 0x0000c43f (0x40) IX[b]
	[20] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
	[21] -1	0	0x00000c00 - 0x00000c1f (0x20) IX[b]
	[22] -1	0	0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[23] -1	0	0x0000e000 - 0x0000e003 (0x4) IX[b]
	[24] -1	0	0x0000e400 - 0x0000e407 (0x8) IX[b]
	[25] -1	0	0x0000e800 - 0x0000e803 (0x4) IX[b]
	[26] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
	[27] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
	[28] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[29] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[30] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[31] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[32] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
	[33] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[b]
	[34] -1	0	0x0000d000 - 0x0000d01f (0x20) IX[b]
	[35] -1	0	0x0000cc00 - 0x0000cc1f (0x20) IX[b]
	[36] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[b](B)
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
	Module class: X.Org Server Extension
	ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "i2c"
(II) Loading /usr/lib/xorg/modules//libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
	compiled for 7.2.0, module version = 1.2.0
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules//libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
	compiled for 7.2.0, module version = 2.1.0
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(**) AIGLX disabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
	compiled for 7.2.0, module version = 1.1.0
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
	compiled for 7.1.0, module version = 8.39.4
	Module class: X.Org Video Driver
	ABI class: X.Org Video Driver, version 1.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
	compiled for 7.2.0, module version = 1.1.1
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.39.4
(II) ATI Proprietary Linux Driver Release Identifier: UNSUPPORTED-8.393.1
(II) ATI Proprietary Linux Driver Build Date: Jul 20 2007 13:50:07
(--) Assigning device section with no busID to primary device
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(--) Chipset Supported AMD Graphics Processor (0x71C6) found
(II) AMD Video driver is running on a device belonging to a group targeted for this release
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x81e3ae8
(II) resource ranges after probing:
	[15] 0	0	0x000a0000 - 0x000affff (0x10000) MS[b]
	[16] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[b]
	[17] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[b]
	[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
	[19] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
	[20] -1	0	0x0000b800 - 0x0000b87f (0x80) IX[b]
	[21] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[b]
	[22] -1	0	0x0000c400 - 0x0000c43f (0x40) IX[b]
	[23] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
	[24] -1	0	0x00000c00 - 0x00000c1f (0x20) IX[b]
	[25] -1	0	0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[26] -1	0	0x0000e000 - 0x0000e003 (0x4) IX[b]
	[27] -1	0	0x0000e400 - 0x0000e407 (0x8) IX[b]
	[28] -1	0	0x0000e800 - 0x0000e803 (0x4) IX[b]
	[29] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
	[30] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
	[31] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[32] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[33] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[34] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[35] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
	[36] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[b]
	[37] -1	0	0x0000d000 - 0x0000d01f (0x20) IX[b]
	[38] -1	0	0x0000cc00 - 0x0000cc1f (0x20) IX[b]
	[39] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[b](B)
	[40] 0	0	0x000003b0 - 0x000003bb (0xc) IS[b]
	[41] 0	0	0x000003c0 - 0x000003df (0x20) IS[b]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin, [x]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
	compiled for 7.2.0, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "UseInternalAGPGART" "no"
(**) fglrx(0): Option "CenterMode" "off"
(**) fglrx(0): Option "PseudoColorVisuals" "off"
(**) fglrx(0): Option "DPMS" "true"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(--) fglrx(0): Chipset: "Radeon X1650 Series" (Chipset = 0x71c6)
(--) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0x0850)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
(--) fglrx(0): MMIO registers at 0xffcf0000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules//libvbe.so
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 9.12
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: RV530
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmGetBusid returned ''
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(--) fglrx(0): VideoRAM: 262144 kByte, Type: DDR2
(II) fglrx(0): PCIE card detected
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) Reloading /usr/lib/xorg/modules//libddc.so
(II) fglrx(0): Connected Display1: DFP on internal TMDS [tmds1]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: SAM  Model: 255  Serial#: 1146106418
(II) fglrx(0): Year: 2007  Week: 5
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 47  vert.: 30
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.644 redY: 0.333   greenX: 0.286 greenY: 0.603
(II) fglrx(0): blueX: 0.152 blueY: 0.079   whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
(II) fglrx(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
(II) fglrx(0): #2: hsize: 1280  vsize 960  refresh: 60  vid: 16513
(II) fglrx(0): #3: hsize: 1152  vsize 864  refresh: 75  vid: 20337
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 146.2 MHz   Image Size:  474 x 296 mm
(II) fglrx(0): h_active: 1680  h_sync: 1784  h_sync_end 1960 h_blank_end 2240 h_border: 0
(II) fglrx(0): v_active: 1050  v_sync: 1053  v_sync_end 1059 v_blanking: 1089 v_border: 0
(II) fglrx(0): Ranges: V min: 56  V max: 75 Hz, H min: 30  H max: 81 kHz, PixClock max 170 MHz
(II) fglrx(0): Monitor name: SyncMaster
(II) fglrx(0): Serial No: HS9P200621
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 	00ffffffffffff004c2d550232325044
(II) fglrx(0): 	05110103802f1e782ad515a455499a27
(II) fglrx(0): 	145054bfef80b30081808140714f0101
(II) fglrx(0): 	01010101010121399030621a274068b0
(II) fglrx(0): 	3600da281100001c000000fd00384b1e
(II) fglrx(0): 	5111000a202020202020000000fc0053
(II) fglrx(0): 	796e634d61737465720a2020000000ff
(II) fglrx(0): 	00485339503230303632310a2020007a
(II) fglrx(0): End of Display1 EDID data --------------------
(WW) fglrx(0): Only one display is connnected,so single mode is enabled
(II) fglrx(0): Primary Controller - DFP on internal TMDS
(II) fglrx(0): Internal Desktop Setting: 0x00000001
(II) fglrx(0): POWERplay not supported on this hardware
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(**) fglrx(0):  PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(**) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 35 modes found for primary display.
(--) fglrx(0): Virtual size is 1680x1050 (pitch 0)
(**) fglrx(0): *Mode "1680x1050": 146.2 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1680x1050"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 +hsync
(**) fglrx(0):  Default mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1280x1024"  135.00  1280 1296 1440 1688  1024 1025 1028 1066
(**) fglrx(0):  Default mode "1280x1024": 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1280x1024"  128.94  1280 1368 1504 1728  1024 1025 1028 1066 +hsync
(**) fglrx(0):  Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x1024"  108.00  1280 1328 1440 1688  1024 1025 1028 1066
(**) fglrx(0):  Default mode "1280x1024": 85.5 MHz (scaled from 0.0 MHz), 50.9 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "1280x1024"   85.51  1280 1344 1480 1680  1024 1025 1028 1083 interlace +hsync
(**) fglrx(0):  Default mode "1280x1024": 77.8 MHz (scaled from 0.0 MHz), 46.3 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1280x1024"   77.80  1280 1344 1480 1680  1024 1025 1028 1077 interlace +hsync
(**) fglrx(0):  Default mode "1280x720": 74.5 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x720"   74.48  1280 1336 1472 1664  720 721 724 746 +hsync
(**) fglrx(0):  Default mode "1280x720": 60.5 MHz (scaled from 0.0 MHz), 37.0 kHz, 50.0 Hz
(II) fglrx(0): Modeline "1280x720"   60.46  1280 1328 1456 1632  720 721 724 741 +hsync
(**) fglrx(0):  Default mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1152x864"  108.00  1152 1216 1344 1600  864 865 868 900
(**) fglrx(0):  Default mode "1152x864": 96.8 MHz (scaled from 0.0 MHz), 63.0 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1152x864"   96.76  1152 1224 1344 1536  864 865 868 900 +hsync
(**) fglrx(0):  Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1152x864"   81.62  1152 1216 1336 1520  864 865 868 895 +hsync
(**) fglrx(0):  Default mode "1152x864": 64.7 MHz (scaled from 0.0 MHz), 43.0 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "1152x864"   64.67  1152 1208 1328 1504  864 865 868 915 interlace +hsync
(**) fglrx(0):  Default mode "1152x864": 58.3 MHz (scaled from 0.0 MHz), 39.2 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1152x864"   58.28  1152 1200 1320 1488  864 865 868 911 interlace +hsync
(**) fglrx(0):  Default mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1024x768"   78.75  1024 1040 1136 1312  768 769 772 800
(**) fglrx(0):  Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz
(II) fglrx(0): Modeline "1024x768"   78.43  1024 1080 1192 1360  768 769 772 801 +hsync
(**) fglrx(0):  Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1024x768"   75.00  1024 1048 1184 1328  768 771 777 806 +hsync +vsync
(**) fglrx(0):  Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768"   65.00  1024 1048 1184 1344  768 771 777 806 +hsync +vsync
(**) fglrx(0):  Default mode "1024x768": 44.9 MHz (scaled from 0.0 MHz), 35.5 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1024x768"   44.90  1024 1032 1208 1264  768 768 772 817 interlace
(**) fglrx(0):  Default mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) fglrx(0): Modeline "800x600"   49.50  800 816 896 1056  600 601 604 625
(**) fglrx(0):  Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz
(II) fglrx(0): Modeline "800x600"   50.00  800 856 976 1040  600 637 643 666
(**) fglrx(0):  Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz
(II) fglrx(0): Modeline "800x600"   45.50  800 840 920 1040  600 601 604 625 +hsync
(**) fglrx(0):  Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600"   40.00  800 840 968 1056  600 601 605 628
(**) fglrx(0):  Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline "800x600"   36.00  800 824 896 1024  600 601 603 625
(**) fglrx(0):  Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480"   31.50  640 656 720 840  480 481 484 500 +hsync +vsync
(**) fglrx(0):  Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz
(II) fglrx(0): Modeline "640x480"   31.50  640 664 704 832  480 489 492 520 +hsync +vsync
(**) fglrx(0):  Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480"   25.18  640 656 752 800  480 490 492 525 +hsync +vsync
(**) fglrx(0):  Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x400"   28.07  640 696 736 832  400 413 415 449
(**) fglrx(0):  Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400"   24.92  640 664 760 792  400 460 462 525
(**) fglrx(0):  Default mode "512x384": 19.7 MHz (scaled from 0.0 MHz), 31.1 kHz, 75.0 Hz
(II) fglrx(0): Modeline "512x384"   19.68  512 528 576 632  384 384 385 416
(**) fglrx(0):  Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "400x300"   24.75  400 408 448 528  300 601 602 625 doublescan
(**) fglrx(0):  Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "400x300"   22.33  400 416 480 496  300 601 605 742 doublescan
(**) fglrx(0):  Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x240"   15.75  320 328 360 416  240 481 482 501 doublescan
(**) fglrx(0):  Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x240"   12.59  320 328 376 400  240 491 493 525 doublescan
(**) fglrx(0):  Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x200"   13.10  320 352 368 416  200 406 407 417 doublescan
(**) fglrx(0):  Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200"   12.59  320 336 384 400  200 457 459 524 doublescan
(**) fglrx(0): Display dimensions: (432, 324) mm
(WW) fglrx(0): Probed monitor is 470x300 mm, using Displaysize 432x324 mm
(**) fglrx(0): DPI set to (98, 82)
(--) fglrx(0): Virtual size is 1680x1050 (pitch 1728)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
	ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules//libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
(==) fglrx(0): HPV inactive
(**) fglrx(0): FSAA enabled: NO
(==) fglrx(0): FSAA Gamma enabled
(==) fglrx(0): FSAA Multisample Position is fix
(==) fglrx(0): NoDRI = NO
(II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) fglrx(0): Depth moves disabled by default
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x8000001d
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): ATI GART size: 128 MB
(II) fglrx(0): [pcie] 131072 kB allocated with handle 0xdeadbeef
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
	[0] 0	0	0xffcf0000 - 0xffcfffff (0x10000) MX[b]
	[1] 0	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b]
	[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[b]E(B)
	[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[b]
	[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[b]
	[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[b]
	[6] -1	0	0xffdff000 - 0xffdff7ff (0x800) MX[b]
	[7] -1	0	0xffdfff00 - 0xffdfffff (0x100) MX[b]
	[8] -1	0	0xffeff900 - 0xffeff9ff (0x100) MX[b]
	[9] -1	0	0xffeffa00 - 0xffeffbff (0x200) MX[b]
	[10] -1	0	0x88100000 - 0x881003ff (0x400) MX[b]
	[11] -1	0	0xffeffc00 - 0xffefffff (0x400) MX[b]
	[12] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
	[13] -1	0	0xffce0000 - 0xffceffff (0x10000) MX[b](B)
	[14] -1	0	0xffcc0000 - 0xffcdffff (0x20000) MX[b](B)
	[15] -1	0	0xffcf0000 - 0xffcfffff (0x10000) MX[b](B)
	[16] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](B)
	[17] 0	0	0x000a0000 - 0x000affff (0x10000) MS[b](OprU)
	[18] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[b](OprU)
	[19] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[b](OprU)
	[20] 0	0	0x0000a800 - 0x0000a8ff (0x100) IX[b]
	[21] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
	[22] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
	[23] -1	0	0x0000b800 - 0x0000b87f (0x80) IX[b]
	[24] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[b]
	[25] -1	0	0x0000c400 - 0x0000c43f (0x40) IX[b]
	[26] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
	[27] -1	0	0x00000c00 - 0x00000c1f (0x20) IX[b]
	[28] -1	0	0x0000dc00 - 0x0000dc0f (0x10) IX[b]
	[29] -1	0	0x0000e000 - 0x0000e003 (0x4) IX[b]
	[30] -1	0	0x0000e400 - 0x0000e407 (0x8) IX[b]
	[31] -1	0	0x0000e800 - 0x0000e803 (0x4) IX[b]
	[32] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
	[33] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
	[34] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[35] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[36] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[b]
	[37] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[b]
	[38] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
	[39] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[b]
	[40] -1	0	0x0000d000 - 0x0000d01f (0x20) IX[b]
	[41] -1	0	0x0000cc00 - 0x0000cc1f (0x20) IX[b]
	[42] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[b](B)
	[43] 0	0	0x000003b0 - 0x000003bb (0xc) IS[b](OprU)
	[44] 0	0	0x000003c0 - 0x000003df (0x20) IS[b](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(II) fglrx(0): detected X.org 7.1.0.0
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
drmOpenByBusid: Searching for BusID PCI:1:0:0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenByBusid: drmOpenMinor returns -19
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0xf0000
(II) fglrx(0): [drm] mapped SAREA 0xf0000 to 0xb7705000
(II) fglrx(0): [drm] framebuffer handle = 0xf1000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0):     Name: fglrx
(II) fglrx(0):     Version: 8.39.4
(II) fglrx(0):     Date: Jul 20 2007
(II) fglrx(0):     Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0):     Build-Kernel UTS_RELEASE:        2.6.22-ARCH
(II) fglrx(0):     Build-Kernel MODVERSIONS:        no
(II) fglrx(0):     Build-Kernel __SMP__:            no
(II) fglrx(0):     Build-Kernel PAGE_SIZE:          0x1000
(II) fglrx(0): [drm] register handle = 0x000f2000
(II) fglrx(0): Interrupt handler installed at IRQ 17.
(II) fglrx(0): Exposed events to the /proc interface
(II) fglrx(0): [drm] ringbuffer size = 0x00100000 bytes
(II) fglrx(0): [drm] texture shared area handle = 0x000f6000
(II) fglrx(0): shared FSAAScale=2
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x008f7000
(II) fglrx(0): FBMM initialized for area (0,0)-(1728,1360)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1728,1050) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1728 x 304
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(**) fglrx(0): Textured Video is enabled.
(II) LoadModule: "glesx.so" (glesx)
(WW) LoadModule: given non-canonical module name "glesx.so"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
	compiled for 7.1.0, module version = 1.0.0
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 16
(II) fglrx(0): GLESX is enabled
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
	Screen to screen bit blits
	Solid filled rectangles
	8x8 mono pattern filled rectangles
	Solid Lines
	Dashed Lines
	Offscreen Pixmaps
	Setting up tile and stipple cache:
		26 128x128 slots
(II) fglrx(0): Acceleration enabled
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(II) fglrx(0): X context handle = 0x1
(II) fglrx(0): [DRI] installation complete
(II) fglrx(0): Direct rendering enabled
(==) fglrx(0): Using hardware cursor
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Loading local sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "CoreKeyboard"
(**) Generic Keyboard: Core Keyboard
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc104"
(**) Generic Keyboard: XkbModel: "pc104"
(**) Option "XkbLayout" "us_intl"
(**) Generic Keyboard: XkbLayout: "us_intl"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/TTF, removing from list!
How did you install the drivers? With the ATI installer, or via YUM? (package manager).
No, this is Arch.. :)
So used "Pacman -S fglrx"
The modules are there and working fine, but only as root..
