Hello i looked a little bit on the internet and i can't find a answer for my problem, first of all i did OC with this CPU on an older setup pumped it up to 3.2 just by rising the fsb everything worked very nice for a very long time, afterwards i started having blue screens i reset bios to default everything was good, now i have the mobo from the title the problem is that i can't rise the fsb at all without making the system unstable(i bought 16Gb@1866 ram that's why i want to oc the fsb), first i tried using bios raised up the fsb the result would be no video output after i tried to rise the fsb and lower the other frequency multiplier still same effect, the only success that i had was to instal an msi application that enables overclocking from windows (i have w8.1) and i started to increment step by step everything was very nice i reached 223 fsb system was running i increased the voltages a little bit, at 224 it crashed therefor i rebooted and surprise when i put the last good configuration crushed again it looks like if i increase the fsb in big steps it crushes but if i just increment it works do any of you have an explanation for that or even better a solution?
