- Feb 24, 2012
- Toronto/Hamilton
I've had my current i7-920 Since 2009 and over the course of its life I've tried many times to hit 4.0 GHz while being stable with a vcore of about 1.42. However no matter what different settings of my own and those from around the web I've tried I've had no luck. I'm hoping maybe some direct help from fellow forums members and overclocking enthusiasts will lead to better results.
My current Mainboard is a: ASUS P6T V2 Deluxe
Ram: 12 GB of Triple Channel G.SKill Ripjaws 1600 Mhz Ram
Cooling: Custom Water cooling with just CPU Loop on EK-XTX 360 RAD and RASA CPU Block
My current settings are:
Temp @ Idle: 37 C
Temp @ 100% Load over 1 Hour: 67 C
-So far I've been Stable at 3.9 GHz with a VCore of 1.425V at 100% Load
-I tried 4.0 GHz with the same VCore and Settings I crashed in 3 Mins @ 100% Load
-I've tried underclocking
-I've also tried using multipliers of x19, x20 and x21
-Under the assumption that this is a Bad Binned CPU I have hence the High Voltages to run stable @ 100% load
What I'm trying to achieve:
- 4.0 GHz or Over
- No permanent Damage to CPU for 5 Months
- Idle Temps Below: 50 C
- Load Temps Below: 80 C
I don't mind trying any extreme solutions as long as i don't damage my CPU permanently or at least for the next 5 months.
Thanks for taking a look, any help and or tips would be appreciated =)
Temp @ Idle: 37 C
- 4.0 GHz or Over
