I got this 512mb stick burning up at 3.1v, but was able to pull some sweat latencies with it. No, it isn't stable. I think if I could keep the heat down on it, it would run fine. If I could fix the heat problem I could try for some more voltage.
I am using an AMD approved heatsink fan that really doesn't cool them that well. I think I would have better luck strapping a couple of 80mm's on there to keep them cool.
What about the alpha timings? RedDragon mentioned something about enabling ECC to someone else. So I tried it myself and had like a 10 second gap to close the app in the task manager before windows froze. Is there anything else I can try?
I have no drive strength options. If so what whould they be?
Has anyone had problems using A64 Tweaker v.05 Beta or v.06 Beta? I am having problem with both. Anytime I make the slightest adjustment then go resart the pc it locks up. I have to end the task in the task mananger right as the app starts.
