CPU-Z TXT Report
Binaries
CPU-Z version 1.71.0.x32
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Timers
ACPI timer 3.580 MHz
Perf timer 3.580 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Athlon XP
Codename Palomino
Specification AMD Athlon(tm)
Package Socket A (462)
CPUID 6.6.2
Extended CPUID 7.6
Core Stepping A5
Technology 0.18 um
Core Speed 1100.2 MHz
Multiplier x Bus Speed 11.0 x 100.0 MHz
Rated Bus speed 200.0 MHz
Instructions sets MMX (+), 3DNow! (+), SSE
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
K7 Thermal sensor yes
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02001002h
Max CPUID level 00000001h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 256 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00000662 0x00000000 0x00000000 0x0383F9FF
0x80000000 0x80000008 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00000762 0x00000000 0x00000000 0xC1C3F9FF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x0020296D
0x80000003 0x00000000 0x00000000 0x00000000 0x00000000
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0x0408FF08 0xFF20FF10 0x40020140 0x40020140
0x80000006 0x00000000 0x41004100 0x01008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000001
0x80000008 0x00002022 0x00000000 0x00000000 0x00000000
MSR 0xC0010114 0x8668CF68 0xFFFFFFFF
MSR 0xC0010015 0x00000000 0x00001008
Chipset
Northbridge VIA KT133A rev. 03
Southbridge VIA VT82C686 rev. 40
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 4x
AGP SBA supported, enabled
Memory Type SDRAM
Memory Size 1536 MBytes
Memory Frequency 133.4 MHz (FSB + 33 MHz)
DRAM Interleave none
CAS# latency (CL) 3.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 6
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type SDRAM
Manufacturer (ID) (00000000000000000000)
Size 512 MBytes
Max bandwidth PC142 (142 MHz)
Part number
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-7-n.a. @ 142 MHz
DIMM # 2
SMBus address 0x51
Memory type SDRAM
Manufacturer (ID) Kingston (7F980000000000000000)
Size 512 MBytes
Max bandwidth PC133 (133 MHz)
Part number 64MX64PC133CL3168
Serial number 061242E0
Manufacturing date Week 32/Year 04
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP no
JEDEC #1 2.0-2-2-5-n.a. @ 100 MHz
JEDEC #2 3.0-3-3-6-n.a. @ 133 MHz
DIMM # 3
SMBus address 0x52
Memory type SDRAM
Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF0000)
Size 512 MBytes
Part number 16LSDT6464AG-13ED2
Serial number 072CE131
Manufacturing date Week 11/Year 05
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
AMP no
JEDEC #1 2.0-2-2-6-n.a. @ 133 MHz
JEDEC #2 3.0-3-3-7-n.a. @ 142 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 04 0D 0A 02 40 00 01 70 52 00 80 08 00 01
10 8F 04 04 01 01 00 0E A0 80 00 00 14 0F 14 2D 40
20 15 08 15 08 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 E8
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 F5
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SPD registers
00 80 08 04 0D 0A 02 40 00 01 75 54 00 82 08 00 01
10 8F 04 06 01 01 00 0E A0 60 00 00 14 0F 14 2D 40
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 D3
40 7F 98 00 00 00 00 00 00 04 20 36 34 4D 58 36 34
50 50 43 31 33 33 43 4C 33 31 36 38 50 20 04 20 06
60 12 42 E0 FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 64 F7
F0 39 39 30 35 32 32 30 2D 30 30 37 2E 41 30 30 00
DIMM # 3
SPD registers
00 80 08 04 0D 0A 02 40 00 01 70 54 00 82 08 00 01
10 8F 04 06 01 01 00 0E 75 54 00 00 0F 0E 0F 2D 40
20 15 08 15 08 00 00 00 00 00 3C 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 B8
40 2C FF FF FF FF FF FF FF 01 31 36 4C 53 44 54 36
50 34 36 34 41 47 2D 31 33 45 44 32 02 00 05 0B 07
60 2C E1 31 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0F
Monitoring
Mainboard Model 8363-686A (0x000001E6 - 0x02348A74) << This is a Soyo SY-K7VTA-Pro
