- Thread Starter
- #21
That’s true. My general browsing experience is very snappy already for sure. I’ve been having some issues with tabs flashing for a second when I switch to them and backgrounds loading weirdly, but those are probably issues with Edge, Firefox, or my WiFi lol.Is something going on in "general browsing situations" that makes you feel that better RAM performance is needed. I would assume this system is snappy AF and additionally that any memory tuning will be 100% inconsequential for the application of general browsing. If something is slowing down your browsing I would look elsewhere.
So PBO is all about power delivery. The CPU uses an algorithm based on 3 general parameters to determine how fast it can boost: clock speed, power draw, and temperature. You can increase the clock ceiling by 200MHz in the BIOS, this is a setting that was mentioned by Woomack above. PBO itself increases the power limits using three parameters: EDC, PPT, TDC. What each of these limits does is explained here, although a lot has changed since that article was written the groundwork is fundamentally the same. Finally the "-30" that Woomack mentioned is the Curve Optimizer. I don't have a strong understanding of, or first hand experience with it, but the article kind of explains.
While it is possible to tweak these settings in windows using Ryzen Master, it is generally preferred to save a BIOS profile once ideal settings are noted. These settings are actually beneficial to tune if you do want to play around with getting more out of the system, but I would recommend a lot of research into what each setting does and how to manipulate it before you start plugging in different settings.
I get that the memory training process can be harrowing if one doesn't know what to expect, but overall having a boot time of 30-35 seconds is still awesome fast in the general scheme of PC history.
The PBO stuff makes sense too. I suppose Auto PBO may be adjusting EDC, PPT, and TDC a bit differently from the Enabled setting even though the clock speed is the same. I’ll have to enable Advanced (which lets me tune these parameters) from Auto and Enabled to see what the differences are. I’ll try to tweak those manually as well as Curve Optimizer. I would definitely like to get the most out of my system.
I’m just not used to the memory training process, but I see what you’re saying about 30-35 seconds being relatively low. I’ll definitely be happy with that for now until they release any BIOS updates that help.
That makes sense since there’s more stuff and all lol. This is my build: https://pcpartpicker.com/list/fpfDLsIronically, I'd think it would be LESS time considering there are less things on a B650 board compared to X670. This generally applies to the high-end... but I have no idea what motheboard you have (create a signature with your hardware... stick around - post at ONE forum! LOL).
I’ll make a signature though with all that information. I’ll also stick around with this one lol. Thanks!
