- Nov 12, 2002
- Rootstown, OH
Been quite a while since I folded, as I haven't had anything that is really worth folding on. I still don't but I figured I should go ahead and get back into the fold anyways.
So I just installed the SMP client on my i3-2100 HTPC CPU, following chasr's guide.
However, I noticed once the install was finished and I started the folding service, fahcore_a4.exe started running at 99% CPU load. Since I installed the SMP client, shouldn't it be running fahcore_a3.exe or fahcore_a5.exe?
I don't know anything, so if this is normal no problem - just want to make sure I didn't screw up the passkey or make some mistake. What is the best way to make sure it is running to its full potential on my PC?
One exception is that I left the memory setting at default - it detected 8GB of ram, so rather than specifying 2001 as chasr's guide instructed, I left it at the default, which was the 8GB.
EDIT: Everything looks fine in the log file, looks like it read the passkey correctly, and I completed my first step on project 7200 in 6 minutes, 2 seconds.
