Hiya Folks!
Thinking about a possible benching upgrade and would love to hear your thoughts, ideas and recommendations. Looking to spend maybe around $1k.
Upgrade objectives and general stuff:
- get some 2D/3D global boints (my h/w boints are decent but my globals stink)
- want something that will be reasonably 2D competitive under cascade so I can use the ss for vga cards
- have a 3-4 of a lot of vga skus so want the ability to run them all in tri/quad sli/xfire (with the cards under water)
Current thoughts/options:
- buy a binned 4930k that should be able to run around 6GHz under cascade. It'd be a definite improvement over my 5.5GHz 3930k. I could also use hardware I already own. The downside is the chip is super pricey and would blow a lot of my budget. Also...the 3930k coldbugs at less than the cascade so would have to run it under ss (leaving cascade for vga's but iirc...most vga's coldbug around -70C-ish)
- do a completely new x99 build but to fit in the budget, would only be able to swing a 5820k...not sure how they do cold and pretty certain that given the chip lottery, the 6GHz 4930k would be more competitive.
- stick with what I've already got and maybe pick up a new vga card
- do nothing and save the cash
Given what I'm going after....are those my best options? Any other options that you think could do what I want to do? What do you think is my best choice atm?
As always...very much welcome any thoughts, feedback, ideas, etc. Plan to make a buy in about a month.
