klingens said:As soon as the firewall and the potential malware runs on the same computer, it's a feel good snake-oil measure, not a firewall.
True, does a virus scanning program not have as good a chance at catching this as a virus scanning dedicated firewall?klingens said:Lots of malware doesn't come as its own executable but a plugin aka DLL to an existing, legitimate program.
If I havent updated them or know a good reason for it to be asking, yes and in two clicks that warning will be gone, not to be seen untill the next change in program X. Most software firewalls give you a warning with a 'Do not ask again' option when a program is looking for access, afterwards they are silent until the program in question has been changed.klingens said:Do you suddenly want Iexplore, msn messenger, etc to ask everytime they open a connection?
Then what would you advise for the user who now only has the NAT firewall of their router as protection? Given both money and space a dedicated firewall is the optimal solution, but lacking both would you advise against a software attempt?klingens said:A firewall running on the PC it tries to protect is useless since malware always can disable or shut down that firewall via local root exploits if nothing else. To do that with a remote firewall you always need a remote root exploit which is magnitudes harder.
Actually your only partially correct. It should only be on when your online. When not connected it can be easily left off. I had dailup and got hit, be it a lil slower. Was around the time before SP2. A firewall is recomened even on dial. It does not need to be set as a startup service though.wise-skiier said:Unless you have a broadband internet connection... you only need Virus Protection. Invest the money in McAfee... it's really good.
