Best Cpu Cooler Rosewill Blackhawk Case
mtdewcowboy
Ankeny Iowa
I am looking for best cpu cooler that will fit in a Rosewill Blackhawk case
I want the Noctua NH-D14 but will it fit? I can remove the side case fan to make something fit.
Im running a Phanteks PH-TC14CS with both fans with room to spare. If that gives you help for size.
Your build is very close to mine
How do like the cooler?
Do you have any pics?
53c? full load on prime 95
Did you have to remove the side 120mm fan?
Thanks for the info
Too bad you didn't wait to learn more. Any case that has a 120mm exhaust fan can fit an NH-D14. I have a 200mm case (less than 8 inches) and the D14 will fit. The Blackhawk is 8.35 inches. And the D14 is or was on sale recently for $75.
I ended up getting this:
Noctua NH-C14 140mm x 2 SSO CPU Cooler
I don't think that you will be able to use the side fan but it should fit nicely. I had a 212+ before getting the H100I and it barely touched the case side and I thinak that they are the same height.
