- Jun 1, 2013
- United Kingdom
Hello!
I am building a £300 gaming rig using the fractal design core 1000. It has support for 3 fans and I have a query on how to configure them.
I will control the fans with SpeedFan for maximum efficiency when it comes to the noise level and performance. I have an idea to draw cold air in from the front and back, then eject hot air from the fan in the side for positive air flow which I have heard is what the ideal setup when it comes to cooling performance. Please could you notify me on which setup is best for the three fans, and if possible, which models/brands are the best considering the budget.
Thanks as always, Max Vandenwyngaerden.
