I'm buying new ram, havent decided which yet cause im waiting on some combo deals but most likely something like this:
Patriot G Series ‘Sector 5’ Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model
122 cm? - THAT can't be right.The cooler is not the best choice but would be an improvement over the stock box cpu. You really should look at going to a 120 mm fan-based tower cooler if there is room in your case for it. You would need a case at least 122 cm wide from outside of case to outside to accommodate it, however.
Personally, I wouldn't try overclocking with any board missing the MOSFET coolers - that's just asking for trouble. However, you can buy MOSFET heatsinks and add them. Or you can provide some other type of active cooling like a small fan blowing straight onto them or a baffle for the rear fan to direct more air over them ...sorry about the broken link, here it is:
http://www.newegg.ca/Product/Produc...28-445^13-128-445-TS,13-131-654^13-131-654-TS
Oops! Missed this post earlier!And I just noticed your comment on the mobos, do motherboards come with that cooler or do you need to buy it like you said?
