- Nov 10, 2012
- Ankeny Iowa
What would be the best pump speed for a D5 vari?
Right now I have it set to 3
It won't. Like I said you want 1.5gpm of flow. Above.that is seriously diminishing returns..At 5 I still dont hear it at all even with all fans off
I dont think from 3 to 5 makes that much difference in temps
Temps good under load? Can't say much unless you give data. Your question assumes we know your loop by heart like you do, no we don't.
If temps are good under proper load tests, you have run P95 AND Heaven at the same time looping for 30 min and checking temps while stress tests are happening, which I'm sure you have done, then all is good?
