Best Ryzen build under 1000$ New your Opinion
Keithn
Here is the best amd under 1000$
CPU
AMD - Ryzen 5 2600 3.4 GHz 6-Core processor
ASRock - B450 Pro4 ATX AM4 Motherboard
Chipset: AMD B450
Memory
G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage
ADATA - Ultimate SU650 960 GB 2.5" Solid State Drive
Hitachi - Ultrastar 7K3000 2 TB 3.5" 7200RPM Internal Hard Drive
MSI - GeForce GTX 1070 Ti 8 GB ARMOR Video Card
Case
Fractal Design - Meshify C Dark TG ATX Mid Tower Case
Power Supply
Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply
need your opinion
Also when do you want to build this? I'm not a huge fan of waiting but 6 months could get you a really sweet system if you're not in a hurry.
I am thinking of buying 2K monitor. I am building this PC for gaming as well as video Editing.
I want to get it ASAP.
I don't see anything wrong with list you came up with. The case is a personal choice, Fractal makes great cases, so if it works for you....I saw the Corsair Txm 650w Psu for a few dollars less but either will do.
I went with an Asus ROG Strix B450-F Gaming MB ($97 on sale) and an AMD RYZEN 5 2600 ($166) with G.Skill TridentZ RGB 3200 RAM($134). I am Very happy with this combo. I run the CPU at 4 GHz max and use the Ryzen balanced power setting. It runs at 4GHz under load but drops down to 1.6 GHz at idle. I bought an Arctic 33 esports one cpu cooler and then added a second Bionix fan. It idles at 28-30C and tops out around 56C while gaming.
It is amazingly fast compared to the I7-870 build it replaced. I kept my GTX1060 3GB video card and my Corsair TX650 PSU.
I also bought a Corsair MX500 500GB nvme HD and it works well but it doesn't perform any better than the Samsung 850 Evo 500gb SSD that I use as my OS drive.
