So I'm thinking of doing a bit of upgrading and was wondering what part would give me best performance boost. I'm not sure if switching over to a new I7 4770k and mb is as cost effective as just upgrading my gpu, heres what i currently have:
I72600 (Stock)
16gb 1600ghz ram (about to up to 24 since i have a spare 8 set sitting by once i make switch to win8.1)
256gb SSD storage
120gb SSD for os (both SSDs are Samsung 840evos)
1tb hdd storage seagate 7200rpm
Sapphire 7950 3gb 384bit
My question is would i get better increase in performance in games like BF4, Arma 3, Landmark. With a new cpu/motherboard upgrade or upgrading gpu, and if I upgrade gpu I'm leaning towards a amd280 as they are just shy of performing as good as a 780 but 200 dollars cheaper, though when looking at benchmakrs there was a synthetic tesselation one that the Nvidia absoulutely out performed by almost three times that of the amd. So which would be best for first update to my system the gpu (and if so which card do you think will give best bang for buck over my current 7950) or the cpu/mobo. Thanks for any insight.
I72600 (Stock)
256gb SSD storage
