best way to attach ramsinks?
Arctic alumina works very well, and is cheaper than as3 epoxy. They work just as well but it comes to the bling$$$:p
If you don't want it permanent, i suggest you put as3 in between the sink and memory, and 4 dabs of silicon on each corner, so you can cut it off if you don't want it anymore
