- Jun 8, 2005
I am currently in the process of re innovating my home network. It's a pretty simple home network setup [Comcast -> Modem -> Router -> Devices]. To illustrate this I have made a diagram to illustrate this.
I currently have the PC\Xbox\Pandaboard hooked up. I will receive the NAS in the next two weeks, and will then use it to the fullest [watch 1080p movies, transcode said movies, stream netflix, backup, storage from outside].
However, I want to add 2x Parallella devices [specialized development platforms] to my network. The problem is that they will saturate 10/100 network non-stop between each other, and I will be out of router ports. I want to put a gigabit switch behind the router, but I don't want to lose performance if the boards are talking while I am copying files from NAS to home at gigabit speeds. Will that be a problem or can switch handle two streams concurrently? What gigabit switch do you guys recommend? I would like it to have 8x ports, be gigabit, under $50 if possible and super stable.
Which brings me to next question: I would like to add a pfsense\smoothwall box in between modem and router like this.
Then I can disable the router and let the smoothwall\pfsense handle IP allocation and port forwarding. [+Snort\Squid]. Should I go with pfSense or Smoothwall? How big is the box requirement? Can I build it for under $400? What do guys recommend? [Only real requirement is if it's silent]
Any advice will be greatly appreciated.
