- Jan 29, 2010
http://pastebin.com/TZnZyfz6
the Conversion function, is going horribly wrong... and i have no idea.
Code:
#include <iostream>
#include <string>
using namespace std;
#include <stdlib.h>
string BINARY = "NULL";
string TempStr = "NULL";
int Bina = 0;
int y = 0;
int Conversion(string Bin)
// Start Loop cycleing though the input
for(int x = (Bin.length()-1); x >= 0; x--){
TempStr = Bin[y]; // Put the current location being calculated into a string so it can be converted into a int
// 16 8 4 2 1
// for example 1 1 0 0 1 which is 25
// Using 1 * 2^4, 1 * 2^3, 0 * 2^2, 0 x 2^1, 1 * 2^0
// 16 + 8 + 0 + 0 + 1 = 25
/* for some reason the result being printed from cout below are:
1 4 = 1 x 2^4 6
1 3 = 1 x 2^3 1
0 2 " 2
0 1 " 1
1 0 " 2
// I have the value calulated added to Bina each cycle.
Bina += (atoi(TempStr.c_str())) * (2^x); // converting the string from before into the integer for the 1 or 0, then * it to get it's value that it holds.
cout << Bin[y] << " " << x << " " << ((atoi(TempStr.c_str()) * 2^x)) << "\n"; // Print out information for debugging purposes.
// ^^ This part is just 1 x 2^4 ect.
y++; // Increase y by one so the cycle though the Binary works in order.
return Bina;
int main()
while(true){
// Reset data for loop
TempStr = "0";
y = 0;
Bina = 0;
// User input
cin >> BINARY;
// Being calculation
cout << Conversion(BINARY) << "\n\n";
