Myself and I
Disabled
- Aug 9, 2001
- Savannah ,GA
OK it seems when i put my visiontek geforce 3 ti 200 over 248/500 it will lock out eventually in UT and 3dmark2001. i do not receive one artifact on the screen as none are visiable. I think if i were to raise the voltage just alittle bit if possible to the gpu i could achieve over 250/500 easy.
Now the geforce 2 ultra was able to get over 250/500 with 4ns ram easy with a 0.18 gpu but would receive some artifacting . If there was a way to to change the voltage this card could be the best overclocker . 4ns ram is not rated for 175/200 but 250/460 or higher. Right now i have the geforce 3 ti 200 at 246/491 with no what so ever atrifacts 100 % stable. if i put the card at 250/500 i receive no artifacts but eventually a lockout i.e 1600*1200 res in unreal T or 3dmark2001 at the dragos scene.
Someone give me some info on this i heard it might be possible to raise the voltage
