- Dec 27, 2008
I have a friend with an older Dell XPS machine. It's a Core 2 socket 775 era computer.
A few months ago I helped him with some upgrades. Went from Windows XP to Windows 7. From a spinner hard drive to an SSD. And also went from 2 gb of RAM to 4 gb.
He's been having this problem of late where he has post failure and gets prompted to go into bios upon every boot or hit the F1 key to continue. Hitting the F1 key allows him to boot normally into Windows. He indicates he checked his CMOS battery voltage and it is putting out the normal 3.0+ voltage. He states he has also "downloaded" the latest bios for the board from Dell but it didn't help. Here are his exact words:
A couple weeks back I asked you about my boot notice of 'failure to post' I was getting. Checked the bios battery & it was still strong at 3.1v. Also went to Dell to check for an update, but there was none. Re-downloaded the last BIOS update they showed (IIRC, dated 2009) but that didn't help either. Any other ideas? BTW, I also have gone in to the BIOS from the prompt & loaded default values, but that doesn't help either.
Machine is not overclocked and as he indicates, restoring the bios settings to default doesn't fix the problem.
Does this indicate a bad bios chip? Or could this be caused by say, a bad stick of RAM?
