- Jun 10, 2009
Hello Im not sure if I should repost this but I am going to anyways so that way others who might oneday run across the problem i have can resolve it without going nuts like i have for the past several days. If you update to the new BIOS 78DBA525.BST and you have problems with programs reading your temps as very high don't worry its a bug in the update. I have reportrd this issue to Biostar and I hope they listen. If you wun into this problem go back to the older version 8DBA113.BST this will fix your temp problem. This ONLY works on the Biostar 790GX A2+ board as i don't have others to test it with. Thanks to all and I hope this helps others in the future.
