- Thread Starter
- #21
Absolutely correct, I failed to realize that the memory clock was still set at 800 Mhz when I was editing the timings. fatigue played a big role that day and trust me I banged my head after noticing when I was suggested to try for 1600.
Currently working with G.Skill on the correct timings right now, feel free to give me suggestions if you want, I would gladly appreciate it. I got it cranking at 1066 and i'm currently surprised that these pair do not like 1333 at 9-9-9 with my current FSB of 280. I upped the CPU_NB up to .150 and the memory voltage at 1.65 and nothing yet. i'm trying to be careful for where else I up the voltage till anyone gives me some sort of a suggestion.
Here is a new screen on where its at. @ 1066mhz I definitely feel the applications running more quicker and smoothly without jerks, but the timings are crazy. they didn't like 8-8-8 as well so 9's were at its stable point.
UPDATE
Alright well I finally gotten to 1333, these sticks don't like tight timings as you can see here in this new shot. going for 1600 G.skill website is down so i'll be tweaking it myself for a while.
UPDATE PART 2
And for the final result
933.3x2 = 1866Mhz for stability reason, I took it off from T1 and change it to T2.
I'm absolutely surprised on the results. credit to chaser on starting me off the correct direction, finding my errors an just over all helping me out.
Biostar and G.skill would be surprised to see the memory running stable on 1866 when few mentioned it wouldn't be possible so I will be posting the
results on their site to show off their awesome products.
Final thoughts: Not bad for a for a budget build at all.
Thanks for all the support.
UPDATE
UPDATE PART 2
