Just starting out. Looking to get a feel for how voltage settings work. Don't want to try increasing voltages as I'm worried about damaging CPUs, but lowering them should be ok, right?
My 10940X on an MSI Creator X299 is running with VCore of 1.154v and VCCIN of 1.914v @ 4.2GHZ and runs hot. In summer I have to drop the CPU back to 3.9 or 4.0 as the idle temps are in mid 40's (Celsius). In winter @ 4.2 idle temp is 30c. I have a H115i RGB Pro cooler.
Are those voltages too high? I've OC'd by setting all core to 42 but haven't tweaked anything else. RAM is F4-3600C16Q-32GTZN (16-16-16-36)
I have 8600K's also running @ 4.2ghz on MSI Z370 SLI Plus boards. A 9700KF running on an ASRock Z390 Phantom gaming 6, a 7900X delidded on an MSI X299 Xpower Gaming AC, a 7820X running on an X299 XPower Gaming AC and a 9600K on an ASRock Z390 Phantom Gaming 9.
All PCs run Corsair liquid coolers, either H110i V2, H110i or H115i. All cases except for 1 are full tower with lots of fans (side, front, rear, in mosts cases a bottom fan too). My case has 12 fans + radiator fans. It has negative airflow.
What would be the recommended voltages for those all @ 4.2ghz with either 32gb or 16gb of DDR4-3200 C16 (Either Corsair or G.Skill) if say I wanted to run them @ 4.5ghz or leave them @ 4.2ghz?
I'm sort of torn between trying to get higher over clocks on some PCs, and cutting power consumption. Given I've done nothing more than set all clock ratios to 42 all my settings are probably too high, if the comments about motherboard vendors setting things too high is valid.
One PC, running Runescape, Discord, Fortnite and Firefox with a GTX 1660 Ti is being hammered something shocking and I suspect sucking more power than any other PC here. I'm going to buy a power meter just to see how much, but in the mean time, would dropping the frequency help?
Can anyone point me to some good guides for my combination of hardware, or offer some suggestions on recommended voltages.
Please and thank you.
