I see.. so its NOT a function of the [auto] setting .. in other words, 'auto' doesnt mean to dynamically alter the voltage supply as needed, but rather to automatically ascertain what the default vcore value is. In that case, if I selected a manual reading of, say, 1.35, it would probably pop up some during max load also, just like it does now under 'auto'.
Ive read other peoples' experience with this CPU-Z voltage readings also, and it seems most people, under full load, experience a raised voltage reading in cpu-z when compared to their 'normal' readings.
BTW, I see in your sig that youre able to hit 3 ghz stable but require a 1.45 vcore boost in the bios to do so. Do you know how hot my cpu would run at 1.45v? Id probably be somewhere near, or over 60 degrees! So I keep it at 2.78 ghz which keeps max temps no higher than 50 under full Orthos load, and vcore fluctuating between 1.328 and 1.364..
