- Oct 31, 2005
- Dallas, TX
I swapped out my D2-A7 for an I45 and I've mostly been pleased with the results so far. However, the voltage required for overclocking the chipset worries me a bit. I've been about as high as 1.3V, but more than that just seems insane. That said, there are images out on the web of people running their I45 at 1.44V. I did install the extra heat-pipe cooling and fan on top of the voltage regulators and replaced the crappy thermal tape they had on there with some nice AS Ceramique. There is also a good amount of airflow around it. The temps have been pretty close to case temperature, but I'm still afraid to push it too far.
So, how far could I take the chip and not worry about burning it out?
Also, I've noticed that my CPU voltage fluctuates between 1.312V and 1.376V while it is at idle (mostly close to 1.312V). When I start running Orthos for example, the voltage moves quickly up to 1.376V (BIOS setting), and then settles down at 1.368V where it stays pretty solidly. I didn't encounter this on my old motherboard. Any thoughts on this?
