Blockage in a new WB no metric allen wrench.
SB system was working normal with 75c on Ib with 1.375vcc at 46ghz
Replaced a old danger den wb with a Swift Apogee Rev 2.$59
Still using a chevette heater core got 3 free years ago.
Ehiem 1250 GPH-320 pump rebuilt the pump last year.
I replaced all lines and checked for dirt in pump which was clean.
Added 1 45 angled enzotech fitting on outlet.
With the new Rev 2. Loop wont take a good prime too much pressure at WB.
While holding wb to the faucet inlet water will only comes out 1 inch on outlet.
Question could it be possible that there was blockage in block before installing it.
Question What are the odds that dirt from my core clogged the block.
There was no dirt in the in drained water pump was clean. radiator dirt ?
I have almost the same cooling in my 1366 except I got orig Apogee,core and d4 up for two years.
Problem Solved Dirt build up in radiator.
Only the 3rd time I removed radiator and flushed in sink since 2004.
Changed water every 6 months also.
I need to get back to the flushing.
Thanks
Thanks
