bigpappa1983
- Nov 13, 2013
Hello all, I am having a little trouble with my new build. First off here is what I am running. Asus z87 plus, i7 4770k, 16gb ram, 256gb Seagate SSD, 3tb HDD, Bluray Burner, GTX 780, h100i......
As of right now neither the GPU or the water cooler are hooked up, im on the stock cooler and on board graphics while I was working out the bugs.
I got the system to post and BIOS came up so I went ahead and popped my windows 7 disc in and restarted. Windows seemed to install quite fine. I had no internet yet so I did not do any windows updates quite yet. After windows was successfully installed I put in the disc that came with my motherboard and ran it to install everything but the junk(Google chrome, Norton junk). After that finished installing the system rebooted and when it came to the log in screen I no longer had mouse or keyboard control and I would BSOD about 10 seconds after the log in screen appears.
That is where I am at now. I can get into BIOS. I cannot boot into safe mode. I am almost thinking I need to just reinstall windows to get the BSOD to stop at least then hook up to the internet to update everything?
On another side issue. The DVI link doesn't seem to work on the motherboard. The monitor I got for the new system: http://overlordcomputer.com/collections/27-monitors/products/tempest-x270oc-glossy
anyways when i first put everything together and powered up I wasn't getting anything on the monitor. I know the monitor powers up and works. So i grabbed my old dusty 15 inch monitor with a VGA connection to try and it works. I was thinking maybe the monitor NEEDS to be hooked into a GPU and not onboard for it to work? Is this a common thing for the DVI not to work but the VGA does for new builds until I get it all updated?
Thank you very much for any input.
