- Jun 29, 2005
- Mississippi
Can't figure out why. Here's the Event Viewer Errors:
Applications
#1
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 2/5/2006
Time: 1:09:00 PM
User: N/A
Computer: XANADU
Description:
Faulting application wscntfy.exe, version 5.1.2600.2180, faulting module msvcrt.dll, version 7.0.2600.2180, fault address 0x0002a800.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 77 73 63 ure wsc
0018: 6e 74 66 79 2e 65 78 65 ntfy.exe
0020: 20 35 2e 31 2e 32 36 30 5.1.260
0028: 30 2e 32 31 38 30 20 69 0.2180 i
0030: 6e 20 6d 73 76 63 72 74 n msvcrt
0038: 2e 64 6c 6c 20 37 2e 30 .dll 7.0
0040: 2e 32 36 30 30 2e 32 31 .2600.21
0048: 38 30 20 61 74 20 6f 66 80 at of
0050: 66 73 65 74 20 30 30 30 fset 000
0058: 32 61 38 30 30 0d 0a 2a800..
#2
Event Type: Error
Event Source: crypt32
Event ID: 8
Date: 2/5/2006
Time: 1:10:52 PM
User: N/A
Computer: XANADU
Description:
Failed auto update retrieval of third-party root list sequence number from: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootseq.txt> with error: This operation returned because the timeout period expired.
#3
Event Type: Error
Event ID: 1000
Date: 2/5/2006
Time: 2:09:03 PM
User: N/A
Computer: XANADU
Description:
Faulting application wscntfy.exe, version 5.1.2600.2180, faulting module unknown, version 0.0.0.0, fault address 0x03c2c407.
Data:
0030: 6e 20 75 6e 6b 6e 6f 77 n unknow
0038: 6e 20 30 2e 30 2e 30 2e n 0.0.0.
0040: 30 20 61 74 20 6f 66 66 0 at off
0048: 73 65 74 20 30 33 63 32 set 03c2
0050: 63 34 30 37 0d 0a c407..
#4
Event Type: Error
Event ID: 1001
Date: 2/5/2006
Time: 2:09:55 PM
User: N/A
Computer: XANADU
Description:
Fault bucket 264964939.
Data:
0000: 42 75 63 6b 65 74 3a 20 Bucket:
0008: 32 36 34 39 36 34 39 33 26496493
0010: 39 0d 0a 9..
#5
Event Type: Error
Event Source: MsiInstaller
Event ID: 11722
Date: 2/5/2006
Time: 4:22:51 PM
User: XANADU\Stavros
Computer: XANADU
Description:
Product: J2SE Runtime Environment 5.0 Update 6 -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action rt, location: C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\patch-jre1.5.0_06.b05\, command: "C:\Program Files\Common Files\Java\Update\Base Images\jre1.5.0.b64\patch-jre1.5.0_06.b05\\launcher.exe" "C:\Program Files\Java\jre1.5.0_06\bin\\unpack200.exe" -r -v -l "C:\DOCUME~1\Stavros\LOCALS~1\Temp\java_install.log" "C:\Program Files\Java\jre1.5.0_06\\lib\rt.pack" "C:\Program Files\Java\jre1.5.0_06\\lib\rt.jar"
Data:
0000: 7b 33 32 34 38 46 30 41 {3248F0A
0008: 38 2d 36 38 31 33 2d 31 8-6813-1
0010: 31 44 36 2d 41 37 37 42 1D6-A77B
0018: 2d 30 30 42 30 44 30 31 -00B0D01
0020: 35 30 30 36 30 7d 50060}
#6
Event Type: Error
Event ID: 10005
Date: 2/5/2006
Time: 4:24:57 PM
Computer: XANADU
Description:
Product: J2SE Runtime Environment 5.0 Update 6 -- You already have this version of the JRE installed. Please uninstall the product through your add/remove programs utility before reinstalling.
Data:
#7
Event Type: Error
Event ID: 11722
Date: 2/5/2006
Time: 4:33:12 PM
Computer: XANADU
Description:
Data:
Note: #'s 6,7 & 8; I deleted the Java Runtime via Add/Remove Programs.
System:
Note:All errors under System are from the Java Runtime errors.
Event Type: Information
Event Source: Service Control Manager
Event ID: 7036
Date: 2/5/2006
Time: 4:25:26 PM
User: N/A
Computer: XANADU
Description:
The Application Management service entered the stopped state.
[Edit] Nothing in problem devices.
Applications
#1
Event Type: Error
Event ID: 1000
Date: 2/5/2006
Time: 1:09:00 PM
User: N/A
Computer: XANADU
Description:
Data:
#2
Event Type: Error
Event ID: 8
Date: 2/5/2006
Time: 1:10:52 PM
User: N/A
Computer: XANADU
Description:
#3
Event Type: Error
Event ID: 1000
Date: 2/5/2006
Time: 2:09:03 PM
User: N/A
Computer: XANADU
Description:
Data:
#4
Event Type: Error
Event ID: 1001
Date: 2/5/2006
Time: 2:09:55 PM
User: N/A
Computer: XANADU
Description:
Data:
0010: 39 0d 0a 9..
#5
Event Type: Error
Event ID: 11722
Date: 2/5/2006
Time: 4:22:51 PM
Computer: XANADU
Description:
Data:
#6
Event Type: Error
Event ID: 10005
Date: 2/5/2006
Time: 4:24:57 PM
Computer: XANADU
Description:
Data:
#7
Event Type: Error
Event ID: 11722
Date: 2/5/2006
Time: 4:33:12 PM
Computer: XANADU
Description:
Data:
System:
Event ID: 7036
Date: 2/5/2006
Time: 4:25:26 PM
User: N/A
Computer: XANADU
Description:
