Help! stock 1700 with a vcore over 2v.
Glitchies
Is it normal for the 1700 to show it is running with a core voltage of over 2V when I have no overclocking going on and voltage in bios set to stock?
https://valid.x86.fr/scx49p
I made sure the bios was set to defaults, I dont have any overclocking software installed (anymore... uninstalled it to make sure)
Both CPU-Z and HWMonitor are saying my vcore is 2.1v fluctuating up to 2.17 every now and then. I am hoping this is just a motherboard reporting this incorrectly.
it was hitting 2.4 when I had it overclocked to 3500... with stock voltages and llc set to auto.
Any suggestions on what I should be trying or looking at?
Oh, my temps are sitting at 34 when idol and @46 under load.
Here is my CPUID HWMonitor Report while under load
Binaries
HWMonitor version 1.3.1.0
Monitoring
Mainboard Model X370 Taichi (0x00000364 - 0x5A2E2890)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6779
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC5
LPCIO Revision ID 0x62
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 38 26 10 00 FF FF
20 C5 62 FF 00 04 00 00 00 00 FF C0 00 01 FF 00 01
30 09 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 02 A0 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6779
Voltage 0 2.11 Volts [0x42] (CPU VCORE)
Voltage 1 2.54 Volts [0x9F] (VPPM)
Voltage 2 3.31 Volts [0xCF] (AVCC)
Voltage 3 3.30 Volts [0xCE] (3VCC)
Voltage 4 12.30 Volts [0xE9] (+12V)
Voltage 5 1.11 Volts [0x8B] (VDDCR_SOC)
Voltage 6 1.20 Volts [0x96] (DRAM)
Voltage 7 0.73 Volts [0x5B] (VIN7)
Voltage 9 0.93 Volts [0x74] (VDDP)
Voltage 10 1.86 Volts [0xE9] (+1.8V)
Voltage 11 1.27 Volts [0x9F] (VIN11)
Voltage 13 5.02 Volts [0xD1] (+5V)
Voltage 14 1.08 Volts [0x87] (Chipset +1.05V)
Temperature 0 32 degC (89 degF) [0x20] (Mainboard)
Temperature 1 47 degC (115 degF) [0x5D] (CPU)
Temperature 3 40 degC (104 degF) [0x28] (TMPIN3)
Temperature 5 46 degC (114 degF) [0x2E] (TMPIN5)
Temperature 6 32 degC (89 degF) [0x20] (TMPIN6)
Fan 1 2086 RPM [0x826] (CPUFANIN)
Hardware registers
bank 0
00 03 A5 03 B9 00 FF FF FF FF FF FF FF FF FF FF FF
10 03 A5 03 A5 03 A5 FF FF 40 00 5B 87 D1 74 E4 00
20 42 9F CF CE E9 8B 96 20 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 50 FF DF 00 1F FF 2D FF FF 10 08 55 00 A3
50 01 FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF
60 24 FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 20 80 2E 80 20 80 20 80 20 80 FF FF FF
80 FF 7F 1F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 00 00
B0 00 00 00 00 00 00 2E 00 04 00 00 34 28 00 04 FF
C0 FF FF FF FF FF FF FF FF FF 03 03 07 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 00 00 00 00 00 00 67 FF FF FF
bank 1
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
80 42 9F CE CE E9 8B 96 D7 00 00 5B 87 D1 74 E4 00
90 20 2E 0F 29 16 E7 00 2E 00 20 2E 20 20 20 1F FF
bank 5
bank 6
bank 7
Hardware monitor NVIDIA NVAPI
Voltage 0 0.63 Volts [0x271] (GPU)
Power 0 5.30 pc (GPU)
Temperature 0 36 degC (96 degF) [0x24] (GPU)
Fan 0 0 RPM [0x0] (GPU)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 202.50 MHz [0xCA] (Graphics)
Clock Speed 1 405.00 MHz [0xCA] (Memory)
Processors
Number of processors 1
Number of threads 16
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
-- Core 4
-- Thread 0 8
-- Thread 1 9
-- Core 5
-- Thread 0 10
-- Thread 1 11
-- Core 6
-- Thread 0 12
-- Thread 1 13
-- Core 7
-- Thread 0 14
-- Thread 1 15
Timers
ACPI timer 3.580 MHz
Perf timer 14.318 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 8 (max 8)
Number of threads 16 (max 16)
Name AMD Ryzen 7 1700
Codename Summit Ridge
Specification AMD Ryzen 7 1700 Eight-Core Processor
Package Socket AM4 (1331)
CPUID F.1.1
Extended CPUID 17.1
Core Stepping ZP-B1
Technology 14 nm
TDP Limit 65.0 Watts
Core Speed 3199.3 MHz
Multiplier x Bus Speed 32.0 x 100.0 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
L1 Data cache 8 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 8 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 8 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 x 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Fh
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
FID/VID Control yes
Hardware:
ASRock x370 taichi p2.0 bios
1700 @stock speeds stock air cooler
Corsair Vengeance 16GB (2x8)
Fresh install of Win 10 Pro (with Ryzen chipset dvrs and Power)
Thanks for the tip. with HWiNFO vcore is showing proper numbers. It appears that cpu-z shows twice what it should be. I can sleep better today, thanks.
I have had issues with CPUz from day one 2 months ago, I would have thought by now they had gotten it straight but no dice.
In HWInfo the tru voltage is CPU SVI2 it's measured at the VRM so that's what your CPU is getting. I have found there's a fair bit of V_Doop in the Ryzen platform. Like setting 1.35V in BIOS gives 1.3V at the CPU
@Johan~
Does the cpu-z reporting differ from one operating system to another? And if so, which one is closest or most accurate?
I think it differs more board to board than OS. On the CHVI seems about the same win10-win7 ~ .05V on the MSI I was testing was closer to 0.03V still high though this is compared to BIOS setting. I just don't think that the crew at CPUz has found the right source to monitor.
