- Sep 5, 2005
Hey guys--
I updated my nForce drivers to 6.66 to try to fix my unknown device problem with raid/IDE-SW(I installed the firewall AND the ISE-SW drivers). I thought i successfully fixed it as my computer would startup fine with no problems for 5 or ten times. Now I am trying to find the max of my CPU to start to do some OCing. These were the settings i was trying when the problem started to occur. Before i had successful boot and ran super pi 32M test(following the guide posted obviously... ) with FSB at 260. Now what happens after I click my name to login to windows is the tray icons start loading then MBM5 startsup, then shuts down by itself and then I get BSOD: IRQL not less or equal. This is what happend when I installed the IDE-SW with the 6.53 nForce except i couldnt even get to windows. Now I cant even boot into windows using safe mode. Help please....?
Genie BIOS Settings:
FSB Bus Frequency - 270
LDT/FSB Frequency Ratio - x3.0
CPU/FSB Frequency Ratio - x10.0
PCI eXpress Frequency - 100Mhz
CPU VID StartUp Value - Startup
CPU VID Control - 1.35x
CPU VID Special Control - Above VID * 123%
LDT Voltage Control - 1.20v
Chip Set Voltage Control - 1.50v
DRAM Voltage Control - 2.8v
DRAM Configuration Settings:
DRAM Frequency Set - 100=RAM/FSB:1/02
Command Per Clock (CPC) - Auto
CAS Latency Control (Tcl) - Auto
RAS# to CAS# delay (Trcd) - Auto
Min RAS# active time (Tras) - Auto
Row precharge time (Trp) - Auto
Row Cycle time (Trc) - 07 Bus Clocks
Row refresh cyc time (Trfc) - Auto
Row to Row delay (Trrd) - 02 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 03 Bus Clocks
Refresh Period (Tref) - 3120 Cycles
Write CAS Latency (Twcl) - Auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - Auto
DRAM Data Drive Strength - Auto
Max Async Latency - Auto
DRAM Response Time - Normal
Read Preamble Time - Auto
IdleCycle Limit - 256 Cycles
Dynamic Counter - Disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(4 Bursts)
__________________
DFI LANPARTY UT nF4 Ultra-D 623-2
Athlon64 3200+ Venice w/ xp-90 hs Silent Cat II 90mm
OCZ Gold edition 2x512
2x 250gb WD 16mb cache raid-0
eVga 6800gt
SB Audigy ZS Plat Pro
NEC DVD burner
Gigabyte combo DVD/CD-RW
tsunami dream 2x120mm fans
enermax 535 psu
aerogate 3 fan controller
DQS Skew Value - 0
Bypass Max - 07 x
__________________
eVga 6800gt
NEC DVD burner
enermax 535 psu
