Hello. On one of my older boxes, I am having difficulty getting new memory to work. It had 2x2GB of PC1600 memory (8-8-8-24 1.6V) running at 1333. It has been about 4 years and one of the sticks went bad. It may have been bad for a while. I discovered the problem when I couldn't install Win 7 to a new hard drive (ran MemTest and found one stick with many many errors but other stick 100% OK). Took out bad stick and Win7 installed without a hitch. Things running fine for a couple of weeks, but had only 2GB of memory, so purchased new sticks with intention of bringing up to 8GB or even 16GB.
Purchased Kingston HyperX KHX16C9B1BK2/8 (PC1600, 9-9-9-27, 1.65V). With 1 stick installed, I can get to BIOS setup, but when Windows starts to load, there is a flash of BSOD before the computer shuts down. With 2 sticks installed, I can't even get to BIOS setup. It hangs right before going into setup (goes through POST routine and says "entering setup", but then hangs).
With 1 stick in, I tried fiddling with the BIOS settings. But not sure what I can safely change. Tried XMP off and on, setting timing from 9-9-9-27 to 8-8-8-24, changed to/from 1333 and 1600, can't change voltage on this MOBO (or at least can't see how since it is on "Auto" and grayed out).
I reset CMOS, but no change. I purchased another set of memory to test (http://www.frys.com/product/6350471?site=sr:SEARCH:MAIN_RSLT_PG), but same problem.
When I put the old single 2GB stick back in, everything works fine, it is just with new sticks (tried 2 different brands/speed).
Any suggestions would be greatly appreciated.
