cgipperich
- May 6, 2014
Hey all! I recently took a position which will require me to do a loooot of editing this coming summer. I'm look for a machine that can effectively run all of the Adobe Creative Suite (less emphasis on After Effects - primarily Premiere and Photoshop). I need something that won't leave me sitting and waiting for hours for projects to render/export. And I'm hoping my budget of $500 will allow for that.
Now I haven't built my own computer before, and if it was mine personally then I may take a stab at it. But this is for my employer so I aim to impress within the confines of the limited budget they allowed for me.
Parts they have on-hand already to reduce the purchase cost include:
-Peripherals: monitor, keyboard, mouse, and even a case (though I don't know which one - just don't include in the build, I can add on later for cheap if need be)
-a "few sticks" of 4gb DDR3 RAM (assuming at least 8gb - so the MOBO would have to be compatible with multiples of those)
-also a "few" 250gb HDDs. I'm not sure if using several of these would beat out having a single 1tb 7200 RPM HDD or not.
So I would need everything else required to make this machine run, which I believe includes the following:
- CPU
- MOBO
- Video Card (1gb at least NVIDIA with CUDA)
- Power supply
- Optical drive
- Sound Card
- OS
If there's any other information I could provide to help my situation please let me know! And thanks a loooot in advance!!!
p.s. if you could use pcpartspicker.com or some equivalent to make it easier for me, I would really appreciate it
- CPU
- MOBO
- Power supply
- Optical drive
- Sound Card
- OS
