I need to piece together a new system for my boys... I confess, I'm getting old and don't follow hardware much these days. I'm looking for something simple that will provide reasonable performance/value. I'd like to spend $700 or less on these three components.
Unless there is a crazy deal out there, I'm trying to only buy through NewEgg... I've used them for many many years now and they always get it right.
Before rebate, this is what I've put in my shopping cart - Shipped for $659.56
MSI N460GTX CYCLONE 1GD5/OC GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127510
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
[COMBO] - Intel Core i5-2500K Sandy Bridge 3.3GHz + MSI Z68A-GD65 (B3) LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.674899
I suppose could scale back the memory... if I install a 32bit OS they would never even use 4GB. It just doesn't feel right spending under $100 on memory though!
The video card looks like I could buy a second one for SLI if my oldest son decides he needs to boost his FPS.
Thoughts/feedback/advice would be appreciated!
Thanks in advance,
Mitch
Thanks in advance,
Mitch
