I know Mayhems Aurora is not designed for long term use, but I don't care. It looks cool and my OC is not pushing my temps to the extreme. So a loss of a few degrees should cause any harm.
Has anyone been using Mayhems Aurora in a system for over a month? Any advise? Which reservoir have you found to work best? On their page they recommend a tube res without a pre-attached pump and no 90 degree angles. The coolant work with my block and my radiator is not a restricted flow model.
