- Dec 27, 2014
- All over the place
- Thread Starter
- #21
I then did a test loop without filling her up with water to check if my routing plan worked okay. It was then I realised I forgot to order one of the two snakes I listed in the opening post, so I had to make an adjustment with the knowledge it wasn't going to be quite as tidy as I had hoped So I filled her up and did my leak test
And this is what she looks like now. Might as well mention that I decided no to do push/pull on the top as would have meant having to remove fans just to change the memory or whatever. Got 3 spare GTs now!
- - - Updated - - -
I've just installed the remaining hardware and connected the other drives. And now I'm doing a clean install of Win10.
- - - Updated - - -
