thanks gtxjackbauer, yes the gpu is going to be included in the loop. I'm not going to replace it with a aftermarket waterblock, gonna try to keep the same shroud but not the same tubing,
but this morning I just found out ek is making a custom asus waterblock "ares 3" that looks pretty sick
finished painting the radiators 1 140mm and 2 120mm. testors diamond dust trying to match the color of the gpus shroud. also got the new fans in. Phobya NB-eloop 1600rpm - Bionic. also matching the gpu. monsoon fittings black.
really like all the different options that caselabs offers. for another example would be the stealth SSD mount that goes underneath the motherboard tray.
what caselabs didn't have an option for was to swap out the ssd side mount next to the hdd side mount on the side of the case underneath the gpu. so I just bought another hdd mount and had to do a little modding relocating the mounts. also needed to filp the way the drives faced cause I got them some air coolers. which I painted the fans metallic red.
heres my attempt to sleeve the 24pin cable. definitely going to try a different approach.
This is so freaking amazing I just wanna scream out loud right now. lol I hope you can entertain us with a new builds at a rate of every 3 months would be really majestic for us members.
