Greetings everyone,
I am looking to build a new PC in a few months (early 2009) and I am just putting together a wish list as to what I would like to build. I play EQ 1 mainly (not graphic intensive) surf the Internet, music, general usage for the most part. I do also enjoy overclocking, the ritual of it and the testing process of overclocking. I am thinking of going Intel and I would like to keep things under 1300-ish max (closer to 1k max the better though) I have a Hanns-G 19inch widescreen I will use from my current PC. (and break out my big old CRT for my current PC). I have been spending time researching, reading reviews and pricing parts. Please let me know if any of you pros have some ideas, suggestions, etc. Thank you in advance. I am also hoping some of these parts I selected will get cheaper as time passes. Part of me thinks I should snag some of the parts if the price feels real good. (like the CM690 case for 39.99 after rebate to save money, stick it in the closet for a few months, etc.) Here we go:
Motherboard: BIOSTAR TPower I45 LGA 775 Intel P45 ATX Intel Motherboard
CPU: Intel Core 2 Duo E8600 Wolfdale 3.33GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
GPU: ASUS EN9800GT ULTIMATE/HTDP/512M GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 (this is prob overkill I run great on a 6600 currently)
RAM: Mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) (8gig)
HD: Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive ( I have 50 gig left on my current 80gig HD)
CPU Cooler: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler (with mounting bracket for 6 dollars)
Arctic Silver 5 thermal compound
Power source: CORSAIR CMPSU-620HX 620W ATX12V v2.2 (may also be overkill, I am uncertain on going with modular power source or not modular)
LG 22x dvd burner Sata
Vista 64 bit for the 8 gig ram handling.
All in a Cooler Master 690 case, I am looking for a more reserved look for my case with good cooling potential. I also do not want to spend a lot on my case to be able to allocate more funds to the innards, but I want a good case for the dollar spent. I though of Antec 900 and I like the looks and what cm690 has to offer, more. I understand both to good from what I have read. Any thoughts, opinions, suggestions? I am shooting for 4.0 or higher OC on the cpu.
