Hello,
In 2009-2010 I built the rig that you can still see in my signature and you lot helped me then as well (and no, you guys did not advise the 2GB RAM, that is my own doing :$). For my first overclock I got a very nice overclock out of the Q9550 where again you guys helped a lot. It has stood by me all these years but mainly because of the RAM/GPU I cannot even play games on low settings anymore as most games have minimum requirements such as 4-6 GB RAM. Anyway, it is time for a new rig and I've been googling and reading up a lot on the current stuff. Keep in mind I am on a budget and I want to spend as less as possible. I'm keeping the case, the soundcard and the monitor.
What I want to do with it:
Basically all I do is use internet, watch movies and play games such as GTA 5, Fifa 15, Call of Duty: Ghosts, Call of Duty: Advanced Warfare, Crysis 3, Battlefield 4, perhaps Assassin's Creed: Unity and Watch Dogs on 1920x1080 at ultra/high settings (perhaps with some AA). The goal is ultra, but if a few games can only run high that is fine as well, I don't wanna put down another 100 or 200$ just for the upgrade from high to ultra. First question: I will try to overclock and get something more out of it, but again I don't wanna spend a lot on a cooler, I was very happy with my hyper 212+ and you can see what I got out of the Q9550, so can I just buy the 212 EVO? It looks to have great bang for your buck results on reviews.
Case: Antec 1200
Motherboard: Gigabyte GA-Z87-HD3
Processor: Intel Core i7 4770
Cooler: Cooler Master Hyper 212 EVO
Memory cheapest options:
1) Crucial Ballistix DDR3-1600 MHz CL9 2x4GB - € 69,80
2) G.Skill RipjawsX F3 DDR3-2133 MHz CL11 2x4GB - € 75,20 (seems much better for the cost so that’s why I think there is something wrong with it lol)
3) Crucial Ballistix Tactical DDR3-1866 MHz CL9 2x4GB - €75,53
Graphics Card:
[Insert your advice]
Harddrive: Western Digital Blue WD10EZEX 1TB
Power Supply: Cooler Master Real Power 620W (served me well and never had any issues, it is 4.5 years old, can I still keep using it?)
I need the most help with the GPU and the PSU. Obviously the GPU will decide what PSU I need. What GPU do you guys think I need with what I wanted (see above)?
OR I can just keep all this, swap the memory and buy 2x4GB DDR2 and a GTX970 or even GTX980 because if I change all the other stuff I can definitly not afford a GTX980..
Hope it wasn't too much to read. Thanks in advance guys! Regards,
Baris
Case: Antec 1200
Graphics Card:
Baris
