- Oct 14, 2011
- Southern Indiana
I have a few threads going asking different hardware questions, but im going to try to consolidate them all here.
First: the parts in my wishlist thus far.
[edit]
I tweaked my wishlist a bit. Here's the update..
Case - After looking over the sniper, i thought the HAF did have a better layout, and has room for a 120.2 radiator up top.
Powersupply - The modular connections arn't as clear as OCZ's (ie not labeled) but im hoping the book will clear it up and ill just label them myself.
Motherboard** Asus Link here - When it comes out. I cant bring my self to trust brands i dont know.
CPU - Unchanged
Memory - Unchanged
ATI Videocard vs Nvidia Videocard - Subject to change as price/product will likely upgrade by the time im ready to buy. Still poking around for a comparable nvidia card.
HDD - unchanged
SSD - Going to give this a shot with ISR running and the Win7 on it.
Soundcard - unchanged
CPU Cooler - Still debating this in my head.
Rom Drive - Not going to worry about Blu-ray just yet, as it takes good software to get it working from what ive read.
CPU Cooler - if i dont go with the water system
Speakers (likely wont get them from here, as i have a cheaper source)
Fan Controller & Temp monitor - To help regulate fan speed (aka noise) during 'under use' times. Tho i dono where to get this unit yet.
Video Card - None selected as of yet. I am looking to get a 3 monitor setup going for both gaming and multi tasking running at 1920x1280 resolution and dont want to have to turn things down to do this.
Sound Card - This is depending on if i end up going with the Sniper mobo or not. If i dont, ill go with something running an X-Fi chip-set and digital output.
PSU - The PSU i had originally picked out was based on outdated knowledge about the 12v rails. Im looking at somewhere between 850-1250 watt PSU in order to have upgrade room for several years. Im also wanting a modular setup because i hate having all that extra crap im not using in the case. Two contenders for this are..
CORSAIR Gold AX
OCZ ZX
These are the 850 variants.
Second:
The Primary game im looking at running is StarWars : The Old Republic, but my gaming will NOT be limited to that. I also play older games and expect to play newer ones as well. As for current games i run..
Day of Defeat: Source
Trackmania United
Portal 2
Half-Life 2 (still waiting on Ep3 )
Eve Online
And other various titles.
Non gaming will be Audio & Video editing but this wont be an every day thing, Along with other various non system taxing tasked.. Web browsing (facebook, youtube, ect) and random usage i cant account for right now . (likely wont happen for months at a time). I want the 3 display setup in games Primarily for MMO UI's, Vent monitoring, Webpage display (while playing) and various other details when games are not ideal to play with 3 displays.
Third:
Im not an amateur builder. But it has been a while since i have put together my own system. But every tower computer ive owned since my first 486 i have put together myself. The problem is tech chances so quickly, and since im not one to stay on the bleeding edge of tech, i dont keep up with every shift of it.
I have no experience with over clocking, but im not opposed to doing *some* as long as there is no risk to damaging the hardware and i see some tangible benefits from it.
Forth: Above all else, i want whatever i end up building to last as long as i can make it last. That means, in short, a motherboard that wont drop off the compatibility list within a year. PCI Express 3.0 is coming and i dont want to be stuck with a board that a 3.0 card wont work in. (i still have a bitter taste in my brain from when they ditched AGP) So upgrade room is Key! In my mind, motherboards are the worst thing to upgrade because of how many comparability changes come with it.
Im having to build an entirely new system because of this. My current desktop is Single core CPU, (capped at 2.0 gig) Caped at 2 gig of system memory, AGP 7800 GS video card (which is about the fastest you can get in AGP form), IDE 160 gig HDD, and SB Audigy sound card. This is all sitting in an old ATX case that does not have good enough airflow to keep the newer dual/quad cores cool. And is powered by a 650Watt PSU which i bought Specifically to power the out of date 7800GS, and is now not powerful enough to run a z68 system the way i want.
So there you have it.. I think ive touched all the bases. If i could get some advice on the hardware i have listed, maybe better suggested hardware to fill the roles, ect.. anything would be helpful.
Budget: Looking at spending around $1500-$2000
I would prefer to stay with Newegg.com, as im going to try to get financing though them. If i absolutely have to i can use Amazon, but id rather not.
Thanks.
[edit]
CPU - Unchanged
Memory - Unchanged
HDD - unchanged
CORSAIR Gold AX
OCZ ZX
Second:
Trackmania United
Portal 2
Eve Online
Third:
Thanks.
