I tweaked my wishlist a bit. Here's the update..
Case - After looking over the sniper, i thought the HAF did have a better layout, and has room for a 120.2 radiator up top.
Powersupply - The modular connections arn't as clear as OCZ's (ie not labeled) but im hoping the book will clear it up and ill just label them myself.
Motherboard** Asus Link here - When it comes out. I cant bring my self to trust brands i dont know.
CPU - Unchanged
Memory - Unchanged
ATI Videocard vs Nvidia Videocard - Subject to change as price/product will likely upgrade by the time im ready to buy. Still poking around for a comparable nvidia card.
HDD - unchanged
SSD - Going to give this a shot with ISR running and the Win7 on it.
Soundcard - unchanged
CPU Cooler - Still debating this in my head.
Rom Drive - Not going to worry about Blu-ray just yet, as it takes good software to get it working from what ive read.
So there it is. Updated list. Bit more than i originally had planned, but still doable i think.
Yup. If you want to be sure you'll have decent support you should buy an EVGA product. I have no faith in returns or warranties on pretty much any electronic product in our modern era and am prepared to accept, albeit begrudgingly, that stuff will eventually explode on me. If you aren't though, you're right for sticking to stuff that has good support. I don't. See my sig (rimshot).
Yeah the Rheobus recommendation was because they handle fan voltage controls easily. I assumed you'd be using something like HWiNFO64 on another monitor for monitoring (it's partially why I keep dual monitors kicking).
The NZXT Sentry 2 is pretty good if you want monitoring, or maybe something from Lamptron.
