ssspy007
Disabled
- Oct 7, 2002
i wanna build my own rheobus since i got a couple of 172mm majors (the ones on sale cyber deal
n e ways the spec sheet says the min watts a 235cfm fan puts out is 26w! and the more i was thinkin bout wirin these up i wanted a rheobus more and more but the strongest one i found was the sunbeam unit but that can only handle 20w per channel. so i wanna build my own. i found a guide to doin it and i understand how fanbus.com but i am not sure on the wattage and the ohms needed to support 2 of these fans and a handfull of cheap 80mm ones. i found these rheostats and they r cheap but i am not sure if they can handle a "major"
and heres another site that sells alot of rheostats (although its expensive) alltronics.com
ok so what do u guys think? u think the cheap rheostat will handle it or should i just give in and buy the sunbeam ??
