- Mar 17, 2012
- Thread Starter
- #21
QBob has a point about going completely overboard. It's a matter of matching porportions. Water cooling is expensive and a maintenance hassle. So why settle for marginally better performance over air cooled or sealed loop (Antec H20 920) system?
Why not include the GPU? Why not a larger radiator and quiter low speed fans. So buck up cowboy. Double down dog.
Double series pump? Why not? It's got head pressure. It's insurance.
Yes, I agree completely with going extreme on an extreme subject (Such as water cooling) I want to start with the best basics I can get, and just add on more things (More fans, accessories, etc)
I will be including the GPUs on a completely separate external loop, however that's after I save up a little more money once I buy the one for the CPU. Eventually, I will also be adding RAM and chipset blocks to the CPU loop. (As you said, might as well go extreme)
I'm getting the largest radiator and fans I can get, 120.4 with 5600RPM fans. I'd go 140mm, but I can't find high performance fans to go with it. I'll just tune the fans down when I can, but turn them up when things start to go under high load to lower temps.
Yes, double pumps are defiantly on my list- triple if the RAM and Chipset blocks restrict flow too much. However, they will have to be saved for later, as my money tree in the backyard hasn't started budding the hundreds yet.
