So it's been some years since I did my last full rig, which currently sits as: Intel Core i7-980 (running at 4.1 ghz), 2 x EVGA GTX 970 SC (4GB) w ACX 2.0, 24gb (6 x 4gb) Muskin DDR3 1600, 1000w Coolermaster silent pro gold PSU, 250 gb Samsung 840 Evo + HHD in a HAF 932 case. The CPU, Mobo, Memory and Case are the oldest parts (2011).
While I do 3D work - I'm mostly doing real-time graphics, which goes hand-in-hand with the true purpose... gaming.
I'm likely getting a Core i7-6700k Processor (thought about a 5930k, but not sure if it's the right choice). But when it comes to overclocking friendly Motherboards for LGA 1151, and Memory that would be an ideal fit (think there are some that go up to 64gb of DDR4 3700? My hope is remaining at least at 32 gb). Any suggestions on where to start?
I guess with that - I am curious what mobo socket may have a longer lifespan when looking at the 2011v3 (5930k) or 1151 (6700k) - I'm hesitant to go with the better but older hardware (5930k) only since it was the position I was in when I got the i7-980, great CPU of a generation where there wasn't much room to go with the socket. I've replaced GPUs and SSDs and such, but when looking at 6700k and 1151 or 5930k and 2011v3 - and my hope to overclock it (general recommendations for cooling?).
I'm not looking to OC my system to an extreme degree, mostly since I'm novice. I'm definitely putting resources into quality components though (looking at enclosed Liquid Cooled CPU systems vs large fans).
Would love any general pointers. Again - it's been a while since I've built a new rig. Excited, but also a bit confused with the different options and directions. THANK YOU for any and all tips!
