First off TIA -
heres what im shooting for.
AMD Athlon 64 3200+ Venice 1GHz FSB Socket 939 - 190.00
// Board Choices //
MSI K8N Neo4 Platinum Socket 939 NVIDIA nForce4 Ultra ATX - 135.00
DFI Socket 939 NVIDIA nForce4 ATX AMD Motherboard - 118.00
// Open for board suggestions //
ATI 100-435513 Radeon X800XL 256MB GDDR3 PCI Express x16 - 325.00
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit - 167.00
Western Digital Caviar SE WD2500JS 250GB 7200 RPM Serial ATA II Hard Drive - (x2) 140.00 (ea) (planning on running them in raid 0+1)
Thermaltake Silent Boost K8 80mm Ball Cooling Fan/Heatsink 31.99
NEC 35XX DVDRW Combo drive - 45.99
Lian Li PC-65B Black Aluminum ATX Mid Tower Computer Case 125.00
Ultra X-Connect 500watt PSU - 70.00 (xoxide is the only supplier I found)
What kind of speeds do you think I can get stable.
TIA
// Board Choices //
TIA
