Hello masters of the clock! I am new to overclocking and was looking for some help. I have been doing some research on overclocking my 3000 Venice cpu. I have hit a wall, I think at 2.35ghz and was wondering if I am missing anything that I could do to improve this or if I should just call it a day and keep with this speed. Here is what I have to work with:
Motherboard: GIGABYTE GA-K8NF-9 939 NVIDIA nForce4 4X ATX AMD
800 mhz hypertransport!! is this what is stopping me from attaining higher clocks?
CPU: AMD Athlon 64 3000+ Venice 1.8GHz 512KB L2 Cache Socket 939 0step
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128268
RAM: OCZ Platinum 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) 2-3-2-5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227210
I run all 4 dimms filled so 4 gigs, I run 2 or 3 gaming sessions sometimes 2 gigs does not cut it.
I use:
3xHTT
HT Link –(783) Is my max really only 800mhz?
9xcpu multiplier
vcore 1.5v Have toyed with this up to 1.7v so far
fsb/HT 261
2T (I can actually run 1T with 4 dimms filled at stock settings not overclocked.
Cas +.5 to 2.5 (have not messed with the other latencies yet)
+.1 to vdimm (this ram can be volt boosted well I read)
SuperPi at stock settings: 56 seconds 1M
SuperPi at 2.35: 39 seconds 1M
Running in complete sync seems to not be the best.
My temps stay cool, cooler with my above overclocked settings as opposed to settings my motherboard creates (aggressive auto settings) high 40’s C for auto-aggressive (1.9mhz) and only mid to high 30’C for my current max clock of 2.35 mhz. I use motherboard monitor, cpu-z, clockgen, and super pi so far. I still have yet to download prime 95. I have only run this with clockgen for a day or two, I have yet to hard set this in the bios. (I have gotten to be good at clearing the cmos and I have only had to remove the battery once)
Any ideas I can try to get more out of this chip? Thank you in advance I have much respect for the overclocking community. From what I can see my memory is sitting at 170ish/200 with my current above settings. I think the ram should run closer to 200. The board does not seem to like 8x multipliers or 2xHTT. Maybe I am doing something wrong. Please help.
I use:
3xHTT
9xcpu multiplier
fsb/HT 261
