Hello all,
I am in the process of building a new system and would appreciate any advise. I want to make sure that all the parts i get will be compatible with one another. I want to try some minor OC on this rig but not anything that will require water cooling. I usually leave my computer on 24/7. Some of these might be a little overkill but i would like to build a good system so it could last me awhile.
Things I've already purchased:
Monitors: 2 Samsung 226BW
HD: 2 Western Digital Raptor X WD1500AHFD 150GB Serial ATA150 Hard Drives
I was also thinking of a third hd for storage.
Things I plan to purchase:
Mobo: ASUS P5K DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard
CPU: Intel Core 2 Quad Q6600 Kentsfield w/ G0 stepping
Case: Antec Nine Hundred Case
Graphics Card: EVGA GeForce 8800 GTS Superclocked 320MB GDDR3
I'm thinking about adding another one in the future so that i can have 2 more monitors. Would that be possible? I would want to connect one DVI port to an additional monitor and the other port to my TV.
Not sure, need help:
Memory - I read somewhere that the p5k3 is picky with memory so i want to make sure i get one that is compatible. I want to get 2 sticks of 2gb.
PSU - I used the psu calculator at this site http://www.extreme.outervision.com/psucalculatorlite.jsp and it recommended me to get a 550. Is that enough. I was still going to get at least a 650 just in case. I'm not really familiar with which brands are good and if single rail or multi rail psu would suit my system more.
CPU Heatsink - I just want to do some minor overclocking as this is the first machine i'm going to attempt it on. Can someone recommend a good heat sink that fits on the Mobo?
DVDRW/CDRW drive - Can someone recommend good brand? I was thinking getting one that uses IDE instead of Sata to make use of the single port on the mobo.
What do you guys think? Any advise or comments will be appreciated.
Thank you
Thank you
