- Sep 9, 2003
- New Jersey
I'm another lazy bum. I could have checked out the tccd bios, but I haven't. When my rig is running decently I am reluctant to experiment. Also, lazy. I think I have another glass of wine.
LOL....Mad is more entertaining.austinbmxnig said:same here...blechhh.....this motherboard is like reading an episode of mad magazine
I'm so tired of RMA's. Thanks for the advice. When I went in for an nF3 board (because I had the 6800 U before the mobo/proc) I found that the MSI board seemed to be the best. Then I click here and find so many problems with it.rseven said:ProperMethodz, most of what I have read says the DFI nf3 board is as buggy or perhaps even worse than the msi. Hoot, one of the mods here, bought one and returned it after 30days in favor of his old msi. (Later he upgraded to an nf4 board , which is one of the better solutions to the nf3 problem) or a modest $70 you can dump the nf3 Neo2 for the ASRock ULI based board, which also takes agp or pci-e video cards. If your Neo2 is buggy I don't think any bios is going to fix it, but that's just my opinion. Good luck.
I've not been able to do the research on what kinds of Issues the NF3 in specific have had. Also companies like to keep those types of things under wraps anyway, making it difficult to do the research.rseven said:Well, I would assume that dfi would do better with a rev B but some of the problems are just nf3 issues in general. The nf4's are much better. Good luck.
rseven said:I am located in Jackson in the middle of New Jersey. (Great Adventure is here)
Good luck with a new bios.
Sniper.nkc said:ProperMethodz
I had the same issue with CSS, game would freeze. You need to go into bios and unlock the hidden features. Go to Cell and do Shift+F2 and ALT+F3 approximately the same time. You will see NAV/ATI=Auto. Disable this. Disable Fastwrite and Sidebanding. This will fix your CSS problem. I had a 6800GT and it was doing the same thing. It seems MSI wanted do overclock the videocard by default .
On the other issue you have with raid, did you see "Boot.ini" missing or corrupted during boot, and did it asked to boot at last known profile? If you have this AND you have a MIRROR RAID then do the following.
You will need to do two things. First, delete and rebuilt your boot.ini. I think I found this information in Microsoft website. Once you fix this, then you can rebuilt your raid. You will need to disconnect your secondary raid device. Leave your primary connected. Boot and go into windows. Now turn off your computer and add the second device and boot. Go to Raid menu and rebuilt your raid.
I hope this will help you. Good luck
MoPMatrix said:!?!?!?
I'm in Jackson too! About a mile from Glories market.
rseven said:That's hysterical! Talk about a small world.
The age range is 14 - 50... yes we get 50 yr olds.rseven said:ProperMethodz, either that site is down or the link doesn't work.
I tried it again and it worked.
I'm too old for a lan party, maybe when I'm younger.
Well, I'm 55 now so in 5 years I be young enough, but thanks for the thought. (My kids send me to Atlantic City when they have a party just to make sure the old fart isn't around!)ProperMethodz said:The age range is 14 - 50... yes we get 50 yr olds.
