anonymousWeasel
- Nov 20, 2019
I'm building a watercooling loop. I'm stuck trying to find a good set of quick-disconnect fittings. My hours-long searches turn up with solutions that don't seem economical. So I decided to draw up a diagram of what I have in mind:
Closest thing I can find on the net is the koolance qd3-ms10x16, but it would force me to buy a female set, essentially doubling the cost for one connection. I am trying to avoid putting compression/clamp fittings at the ends of each tube. Can anyone suggest similar fittings and are there better solutions or corrections to make? Your help is greatly appreciated.
List of additional hardware I'm dealing with, may be relevant:
fractal design nano s
ek-supremacy-mx intel
ek vector strix rtx 2080 gpu block
ek coolstream se 280
d5 pump 12v | 50psi
d5 pump 12v | 50psi
